 Post subject: terminal Report-Seagate ES.2 HD directions for hyperterminal
PostPosted: December 15th, 2010, 23:56
Hallo all:
I borrowed a PC machine to see if I can get data off a non booting Seagate HD
as a Mac guy - am not familiar with Hyperterminal or Putty - so looking for some step by step instructions on how to do this
anyone , can you direct me a bit here ?
cheers in advance :
 Post subject: Re: terminal Report-Seagate ES.2 HD directions for hyperterminal
PostPosted: December 16th, 2010, 0:50
Not so hard. There are plenty of post here and all over the internet on this one. You can search here for 7200.11 or 7200.12 busy or 0 LBA and you will find all that you need to know and plenty of guides and what nots. Just search
Iorana Haraharaini
PostPosted: December 16th, 2010, 1:00
say poehere:
Cheers for the reply :
I will seek
looks like a ridgeback
PostPosted: December 16th, 2010, 2:13
Here is the "standard" 7200.11 DIY bug fix procedure:
http://forums.seagate.com/stx/board/mes ... 467#M18467
ES.2 drives use the same procedure, but with a little twist:
http://www.msfn.org/board/topic/129551- ... 0cc-state/
PostPosted: December 16th, 2010, 3:01
hallo ;
I keep getting error message in hyperterminal - about another program using telephony -
and cant find ports - to set port setting in XP -
with modem on I have " connect thur com 3 - with modem disabled - only TCP shows
cheers:
PostPosted: December 16th, 2010, 4:38
Which interface cable / circuit are you using?
If you are using a USB-serial TTL cable, then you need to install the driver for the USB-RS232 bridge chip. This should have been supplied with the cable.
PostPosted: December 16th, 2010, 16:26
Say Fzabkar:
i am using a USB to IDE / SATA cable with separate power cable
so do I use the IDE/SATA driver or USB to 232?
cheers:
PostPosted: December 16th, 2010, 17:47
The drive has a 4-pin connector for serial terminal access. You need a separate interface cable/circuit to access the Tx/Rx pins in this connector.
PostPosted: December 16th, 2010, 20:38
say fzabkar:
ok - I was thinking a terminal report could be done with the IDE/SATA cable - the 3/4 pin cable was for the bricked /BSY HD
order cable - will report once I get all this figured from the OVERCLOCKED site direction
cheers for your patience
enjoy weeks end
Users browsing this forum: No registered users and 138 guests
