 Post subject: WD10EADS-00L5B1 BSY
PostPosted: December 11th, 2010, 7:30
Hi guys (girls, too? ;)),
I have a WD10EADS-00L5B1 which does recal, but just stays BSY. After hot swap I was able to read the modules, but I cannot find the source of the problem. Attaching full SA tracks -- can you see any problem in there?
Thanks!
-fayn
WD10EADS-00L5B1_BSY.rar [3.48 MiB]
Downloaded 422 times
 Post subject: Re: WD10EADS-00L5B1 BSY
PostPosted: December 11th, 2010, 8:03
i guess that your having Heads problems here
chk heads 1st.
PostPosted: December 12th, 2010, 16:59
If you try to read SA without hotswap, can you read anything?
Is mod 11 readable?
PostPosted: December 14th, 2010, 13:10
Without hot swap just BSY i.e. cannot read anything :(
PostPosted: December 14th, 2010, 14:31
What happens when you replace the PCB with a reprogrammed ROM?
PostPosted: December 14th, 2010, 15:24
And beside SA tracks, can you read modules by ID after hotswap?
PostPosted: December 14th, 2010, 18:09
Only very few: 01, 30 and 47 :(
I believe one of the modules is damaged, but I cannot find out which one :?
PostPosted: December 31st, 2010, 5:14
Ok, since I have not had success with this one I would like to kindly ask if anyone could fix this ROM / SA issue for some bucks. It makes no sense for me to buy the PC3K etc.
Thanks and a Happy New Year!
:druunk:
P.S. To summarize the problem briefly: I have a WD10EADS-00L5B1 drive which just stays BSY after power on. After a hot swap, I can read the SA by tracks, but not by modules.
Users browsing this forum: Google [Bot] and 49 guests
