 Post subject: Rewiring the SATA data connector
PostPosted: December 20th, 2010, 1:54
Hi, I have a 500GB Seagate Barracuda HDD.
The plastic bit of the data connector on the HDD has fallen off and a few pins so ... I have cut a spare SATA cable and noticed there are 8 wires. The SATA connector only has 7.
I want to check with you guys first.
It's a spare HDD, no data lost, it was my 2nd backup external HDD so this is purely a self challenge.
1. With the spare SATA cable, I noticed the 4th wire from the non-L shape side is not attached. Is this right? So the other 7 wires are connected straight (not crossover).
2. Any tips for solder ironing finely? So I don't stick 2 or 3 wires together.
3. There are 4 active wires and 3 ground wires. Is it ok to leave out the 3 ground wires?
Thanks.
 Post subject: Re: Rewiring the SATA data connector
PostPosted: December 20th, 2010, 4:36
refer to here
http://www.allpinouts.org/index.php/Ser ... achment%29
google: SATA cable pinout
for more details
hope this helps u here :roll:
Users browsing this forum: No registered users and 253 guests
