 Post subject: changing pcb of st3500418as
PostPosted: January 5th, 2011, 17:49
Hi i have two seagate hard disk, the same model are the same but the pcb appears different.
One hard disk is working, and other dosen't work, bios dosen't detect.
It's possible to change the pcb from the working model to broken model?
It's dangerous if the pcb are not the same?
Any idea to get back data from the hard disk it's not working?
 Post subject: Re: changing pcb of st3500418as
PostPosted: January 5th, 2011, 18:44
you cannot just board swap that family.
what problems are you having with the bad drive
PostPosted: January 5th, 2011, 18:48
If PCB looks different means it's really different, so you'll not get lucky with that.
You can even get the situation worse.
PostPosted: January 5th, 2011, 19:52
My problem i turn the hard disk, sounds a littel bit no loud, stops, a few seconds later, again sounds,and keep for a few more times, and after 30 seconds dosen't sound anything.
What can i do?Currently i have the disk plugged into an external usb sata adapter.
So if i change the pcb will be a new nightmare?
PostPosted: January 5th, 2011, 20:01
if the drive is not spinning up , but it sound like it is trying to. most likely the motor has seized and it is not something you can fix on your own.
If it is spinning up to speed and clicking and stopping, most likely the reading mechanism is failed and this is also something you cannot fix. ( let me rephrase, you can try, but 99% you will fail and cause more damage)
Get a pro to give you a free diag locally if you can
PostPosted: January 5th, 2011, 20:15
what do you mean Geta pro to give you a free diag locally?
You mean get a profesional service in my area to do a diagnostic?
PostPosted: January 5th, 2011, 22:58
Yes that is what he means on this one Go to a DR company in your area and they will do a free diagnostic exame of your HDD and give you a price to fix it.
Iorana Haraharaini
PostPosted: January 6th, 2011, 7:45
If you say the data is valuable, it's the only option you have.
PostPosted: January 8th, 2011, 18:56
See the following thread, but heed the warnings:
http://forums.seagate.com/t5/FreeAgent- ... 242#M11384
Users browsing this forum: No registered users and 96 guests
