 Post subject: seagate 1tb drive photo recovery
PostPosted: January 8th, 2011, 18:06
hi anyone can give me advice
i got taken some xmas photos of my family
my wife was carrying the brand new seagate drive in her bag at the airport
and it fell out of there
i can hook it up see all the files there in windows and atola imager see the folders
but when i do a recovery all im getting is the yellow folders
and none of the jpegs
they are coming up zero bite
i ran atola imager and done the test on the drive and it says
its working fine no issues at all
very weird problem
could this be a problem with the write head possible damaged in the unit
but diagnostic comform its ok
any advice as i like to recovery my family xmas photos of this year :)
tried to reimage with getdata but again yellow folders no images
 Post subject: Re: seagate 1tb drive photo recovery
PostPosted: January 9th, 2011, 7:33
First of all, image the drive and check the results of the image.
After that you can open the folders and check the JPG files in hex to see if they have at least correct header first of all.
PostPosted: January 9th, 2011, 20:04
You do data recovery for a living?
Is this just a joke? Don't you have copies of your pics? Don't you have backups?
www.datarecoveryne.com
PostPosted: January 9th, 2011, 20:10
yes i do data recovery for a living
photos on the main hard drive but the camera data was wiped when i checked it at home
so it must had got wiped at the airport
its a crappy seagate brand new possible bad sectors if the photos are on those sectors
then goodbye data for every
which hence the pros can not sort out
i got the nice yellow folders but no image remains zero
heads check out fine
PostPosted: January 9th, 2011, 21:05
I see. Very bad situation....
cron
