 Post subject: Is this a damaged PCB?
PostPosted: January 12th, 2011, 17:31
Please help me identify if this is a damaged PCB.
My WD5000AAKS passes SMART, boots up, there are some clicking sounds, but Windows 7 does not recognize it, offers to format it, slows down and then freezes completely. I'm not a hard drive expert, and I was wondering if the black smear on the PCB is normal or a sign of a damaged PCB.
I know that the drive is cheap to replace, but I don't have a 100 percent of the data backed up and I'd like to at least be able to get inside it and transfer the files over before tossing it.
thanks for any help you can give
 Post subject: Re: Is this a damaged PCB?
PostPosted: January 12th, 2011, 18:47
At first, try cleaning all contact pads with pencil rubber (only those in use not the whole PCB), mostly those at the bottom side of the PCB.
If things did not get better, then your problem is much more serious, and take in MIND that all your actions from this point on (or lack of such) could lead to complete impossibility of further recovery, even in data recovery lab.
DataRecovery.bg
PostPosted: January 12th, 2011, 21:32
The "black smear" is normal epoxy covering the motor connection
PostPosted: January 13th, 2011, 3:08
Ups my fault ;)
DataRecovery.bg
PostPosted: January 13th, 2011, 11:17
Thanks. So much for that I guess
PostPosted: January 13th, 2011, 17:03
Clone your drive and use data recovery software on the clone. You need to use a cloning tool that knows how to deal with bad sectors.
See http://forums.seagate.com/t5/Barracuda- ... 822#M22449
PostPosted: January 13th, 2011, 17:31
Without knowing all the details, I'd say that your PCB is the likely culprit, though you could have a weak head. Some of these drives will detect and even let you read sector 0 before going offline and give UNC errors for every sector thereafter. If the data is not important, RMA the drive. If the data is important, seek the assistance of a data recovery professional.
PostPosted: January 16th, 2011, 13:06
Yesterday I got in for an hour or two, long enough to get out much of the data I needed. The drive kept going out, but then back on again, until windows froze.
Thanks for the suggestion. I'll try HD Clone next.
Users browsing this forum: Google [Bot], michael chiklis and 63 guests
