 Post subject: Clicking WD3200BEVT
PostPosted: January 17th, 2011, 10:29
Hi there,
Got a 3x clickin WD3200BEVT-22ZCTO (O or zero/0 at the end).
After some research it appears it's a heads crash.
Any advices would be welcome.
Cheers,
m.
 Post subject: Re: Clicking WD3200BEVT
PostPosted: January 17th, 2011, 10:34
If the data's important on that drive then i would recommend finding a professional in your area to do a proper Diagnosis of the drive to determine what can be done.
Clicking WD hard drives typically are bad heads, but sometimes it could be electrical. But if you are unsure of what to do , then I would not risk it.
PostPosted: January 17th, 2011, 11:46
Don't discard head crash, but as Cleanroom says, without the propper tools, and knowledge it could be very very difficult.
Send it to a Pro
PostPosted: January 17th, 2011, 12:08
Yes that's what I've tought about the situation as well... Thanks dudes !
Any clue about any pro services around switzerland ?
Thanks,
cheers,
PostPosted: January 17th, 2011, 12:48
If you don't mind crossing the borders, it's no problem. I don't remember at the moment if there are members of this forum in Switzerland, maybe will show up and you can get in contact with PM .
PostPosted: January 17th, 2011, 17:29
User "Falther" is in Austria, don't know of anyone in Switzerland.
PostPosted: January 18th, 2011, 5:38
Look at the pro's webs. Some of them have international offices.
Users browsing this forum: No registered users and 42 guests
