 Post subject: buying 1 tera hard western digital or seagate
PostPosted: January 21st, 2011, 16:18
due to crouption in 750 gb western digital i need a new hard to backup data and then send form warrrenty claim plz guide does the disk read error problem could occur again in new hard some detaiil about this problem
 Post subject: Re: buying 1 tera hard western digital or seagate
PostPosted: January 21st, 2011, 16:28
Samsung or Hitachi
PostPosted: January 21st, 2011, 19:46
Cleanroom wrote:
Samsung or Hitachi
Agree buy a Samsung or Hitachi to use for you. Stay away from WD and Seagate if at all possible
Iorana Haraharaini
PostPosted: January 22nd, 2011, 4:33
thanks but only avaiable in market is wd and seagate
PostPosted: January 22nd, 2011, 8:40
i recomend you seagate.
ZeBong
" Россия еще раз"
PostPosted: January 22nd, 2011, 14:06
buy 2x Seagate then, put them in raid 1, so you can feel a bit safer :wink:
Reševanje podatkov - Tannaris
PostPosted: January 22nd, 2011, 19:00
If you decide on RAID, choose an enterprise class drive, eg ES.2. These models support Error Recovery Control (ERC) by default. Standard retail drives that don't support ERC will drop out of the array if they exceed the RAID controller's time limit for reads or writes. WD calls this feature Time Limited Error Recovery (TLER), while Samsung refers to it as Command Completion Time Limit (CCTL).
Users browsing this forum: Google [Bot], Majestic-12 [Bot], pepe and 66 guests
