 Post subject: Need FW WD15EADS-11P8B1
PostPosted: January 21st, 2011, 10:08
We need FW + ROM for one WD15EADS-11P8B1.
Patient stay on busy. We supposed U12 defect.
Many thanks
 Post subject: Re: Need FW WD15EADS-11P8B1
PostPosted: January 21st, 2011, 10:35
Version?
PostPosted: January 21st, 2011, 11:45
PCB version: 2061-701640-402
FW version ????
PostPosted: January 24th, 2011, 6:56
Nobody have this FW ?
It's possible the FW version is 80.00A80.
PostPosted: January 24th, 2011, 7:20
You don't get , you need say which ROM Firmware version you need , there are a lot.
For example :
WDC WD15EADS-00P8B0-01.00A01
>Ключ технорежима
>Ключ технорежима........................ : Ok
>ОЗУ:
>Чтение информации о HDD................. : Ok
>К-во головок............................ : 6
>Cyl Count............................... : 192
>Таблица зонного распределения........... : Ok
>SA SPT.................................. : 1980
>ПЗУ:
>Чтение Flash Dir........................ : Ok
>Чтение ПЗУ.............................. : Ok
>Размер ПЗУ.............................. : 256 Kb
>Версия ПЗУ.............................. : 70.2GA
>Поколение ПЗУ........................... : 70.2HA
>Версия таблицы связей................... : 03.0A.
>Конфигурация головок.................... : по карте
>К-во используемых головок............... : 6
>Отключенные головки..................... : No
>Карта головок........................... : 2,3,4,5,6,7
>ROM Firmware version.................... : 0070002G
>Service area:
>Чтение каталога модулей................. : Ok
>Доступны копии SA....................... : Копия 0,Копия 1
>Чтение конфигурации..................... : Ok
>Master Password......................... : Не установлен
>User Password........................... : Не установлен
Angel Data Recovery
PostPosted: January 25th, 2011, 12:35
If ROM is dead === we can't read ROM version.....
But I think it's the FW version it's 80.00A80.
PostPosted: January 25th, 2011, 12:38
You can read it from SA
PostPosted: January 25th, 2011, 15:14
I don't access to SA....
PostPosted: January 25th, 2011, 15:17
Well, there is one in the files area here:
http://files.hddguru.com/download/PC-30 ... /DragFly3/
PostPosted: January 26th, 2011, 5:50
Thanks but it's not the same ROM... It's for 00P8B0 with FW 01.00A01... Not for one 11P8B1....
Bye
Users browsing this forum: Austinblake22 and 68 guests
