 Post subject: Corrupt Fujitsu Firmware :(
PostPosted: February 3rd, 2011, 20:58
I've got a 120gb Fujitsu Apple Branded drive that won't mount.
Model# MHW2120BH
Tried swapping the pcb board with another drive that has EXACT same info as original drive, down to the date created.
No joy.
I didn't see a rom chip on the pcb board to swap.
Besides using a PC3K is there any way I can fix this problem?
Thanks in advance!
 Post subject: Re: Corrupt Fujitsu Firmware :(
PostPosted: February 3rd, 2011, 23:19
Can you upload a detailed photo of the component side?
Does the drive spin up, or attempt to spin up, with the original PCB?
PostPosted: February 4th, 2011, 0:49
"Won't mount" isn't sufficient info.
Is it recognized under Disk Utility?
Does it spin up? Make clicking noises? Make soft calibration noises?
It may have nothing to do with the PCB . . .
http://www.datasaversllc.com
PostPosted: February 4th, 2011, 2:44
Sorry I didn't post details earlier.
No software will detect drive, including Disk Utility.
It powers on, spins fine, just doesn't mount. No clicking, weird noises, heat, etc. Everything appears normal.
Here are pics of board. Sorry couldn't get 1 good one.
PostPosted: February 4th, 2011, 7:24
I don't think it's a PCB problem. I think it is bad heads w/ possible media damage.
PostPosted: February 4th, 2011, 11:36
Agree, its not a PCB problem.
www.datarecoveryne.com
PostPosted: February 4th, 2011, 13:04
Can you elaborate on why you think that is the issue?
And not a pcb or firmware problem?
Bios won't recognize the drive so I didn't think the issue was bad heads.
PostPosted: February 4th, 2011, 13:13
I'm guessing you guys think that because when I swapped boards, I get nothing, right?
PostPosted: February 4th, 2011, 13:43
I'm guessing it is because we see drives like this often and the symptoms you describe typically (read: not always) have the causes that I describe . . .
Passport info on these are stored on the platters. No read = no I.D.
PostPosted: February 4th, 2011, 19:54
The drive needs to retrieve the bulk of its firmware from the platters. A bad head may prevent it from doing that.
See newbie-info-from-and-for-newbies-about-firmware-etc-t6562-20.html
Users browsing this forum: Bing [Bot] and 66 guests
