 Post subject: Barracuda 7200.10 failed heads change.
PostPosted: February 4th, 2011, 6:23
I need some help please, I have made heads change many times in barracuda 7200.10 and has never worked, but in the other series of Seagate I have good experiences.
I'm currently using HDRC tools.
Please someone has an explanation for this, or similar experience?
Thanks a lot in advance
 Post subject: Re: Barracuda 7200.10 failed heads change.
PostPosted: February 4th, 2011, 6:29
post the terminal log.
ZeBong
" Россия еще раз"
PostPosted: February 4th, 2011, 8:06
hd doctor for seagate [terminal mode]
Reset
4096k x 32 DRAM
GALAXY2D - 1_Disk S-6B 06-09-26_12:43
Buzz HM HM HM HM HM HM HM HM HM HM HM HM
PostPosted: February 5th, 2011, 9:06
Still head problems...
ACELab partner
PostPosted: February 5th, 2011, 11:52
Almost sure it's a head problem still. If you've done these before and are pretty confident in your procedure, then may there is some damage to the platter surface that is killing the replacement heads.
PostPosted: February 7th, 2011, 12:12
i think is media damadge.
have you try to see the heads in the microscope ?
ZeBong
" Россия еще раз"
PostPosted: February 7th, 2011, 13:05
ebordon wrote:
I have made heads change many times in barracuda 7200.10 and has never worked.....
.....I'm currently using HDRC tools.
From your post I think 2 things are wrong. your process is not good, and the tools you use are not reliable.
Have you tried changing the heads on 2 known good models? if process is good both should work good after head change as are healthy. I think before you can take any advise on this case you really should review your procedures.
PostPosted: February 9th, 2011, 12:37
Hi
The problem was in the tools, I bought new tools and the heads swap works great.
PostPosted: February 10th, 2011, 18:25
What did you bought?!?!
ACELab partner
PostPosted: October 10th, 2011, 18:35
would you pm me to say wich tool are you currently using?
Users browsing this forum: No registered users and 82 guests
