 Post subject: Can I change mechanical part of a disk to another PCB ?
PostPosted: February 4th, 2011, 14:56
I'm planning change the complete PCB of a damaged hdd from another HDD with the same model and runnign ok , to recover data on the failing HDD.
As this link says. (http://www.datarecoverynj.com/how.html)
¿ It is posible ? ¿ Is service area in the same location ? could the new PCB read data from another disk exactly the same model integrated circuits and firmware?.
 Post subject: Re: Can I change mechanical part of a disk to another PCB ?
PostPosted: February 5th, 2011, 9:18
No.
ACELab partner
PostPosted: February 5th, 2011, 11:50
You've left a lot of variables out such as, drive brand and model which are two of the most important designations. There are drives where you can swap PCB's without a problem, but there aren't many, especially when talking about newer drives. My advise would be to do a little research on the type of drive you have, and then search through these forums for people who had similar problems.
PostPosted: February 5th, 2011, 19:54
YES!!! I have recovered data. ( more about this issue in the following link).
data-recovery-replacing-damaged-pcb-from-another-one-t18465.html
