 Post subject: Delays found in hard disk.
PostPosted: December 20th, 2010, 12:18
hello.
i have used HDD Regenerator and it showed 0 bad sectors and many
delays in the hard disk.
i have used HD Tune Pro and found some errors .
i am uploading the pics pls help and tell some software through which i can fix these delays in my hard disk.
screenshots:
 Post subject: Re: Delays found in hard disk.
PostPosted: January 19th, 2011, 8:28
LOOL ! I am gonna try to reply on this one...
Ok the software that i would use is voctoria for windows.
And i would set the timeout to 400ms.
Make sure you select remap :)
PostPosted: February 5th, 2011, 17:59
As a explanation for last comment:
The last version is Victoria 4.46b.
In program options u should choose BUTTERFLY scaning and Advanced Remap for best possible combination.
Good luck.
