 Post subject: Maxtor Plus 9 120GB ATA/133: 6Y120P0032211 PCB is damaged!
PostPosted: February 3rd, 2011, 9:45
The PCB from my HDD is crashed!
I look for a replacement PCB for this HDD.
Maby somebody can help me?
About HDD: Maxtor DiamondMax Plus 9 120GB ATA/133 HDD.
Type 6Y120P0032211 date:12nov2003
 Post subject: Re: Maxtor Plus 9 120GB ATA/133: 6Y120P0032211 PCB is damaged!
PostPosted: February 3rd, 2011, 11:39
Crashed? Could you explain exactly what is doing the drive?
Also if you could upload some photos...
Maybe you could repair the PCB.
PostPosted: February 3rd, 2011, 17:42
You can replace the PCB, you need to match only 2 things:
The 5 letter code in the PCB's connector, and the 2 letter form the 4 letter code on the TOP lid, this way:
M,?,?,M where M is the matching letter.
Good luck,
Janos
PostPosted: February 4th, 2011, 5:19
In my experience you have to match only 6YxxxPxxxxxx, and pay attention for the date of manufacture. Drives released before 2003 or at the beginning of 2003 have different PCB with external ROM+ SA head is 2 instead of 3. ROM code is incompatible also.
DataRecovery.bg
PostPosted: February 5th, 2011, 17:37
Hi everbody, Ihave looking my PCB and severall numbers onit.
Mayby somebody can help me with a PCB board from:
"Maxtor DiamondMax Plus 9 120GB 120 GB 6Y120P0 YAR41BW0 040111300 Hard Drive PCB". :?:
thanks to all that want help me!!
Stirf64 :D :
PostPosted: February 6th, 2011, 6:00
Post a pic of your bad PCB
PostPosted: February 6th, 2011, 8:16
The 5 letter code have inside this sub-family marking what you have wrote. ;)
Anyway, more type of 5 letter code can match for one drive, but if u want to be 100% sure, you should match what i have sad.
This is clearly enough.
Janos
Users browsing this forum: Google [Bot] and 87 guests
