 Post subject: Seagate IDE and SATA heads interchangeable?
PostPosted: February 1st, 2011, 18:58
I have a 250GB sata, 7200.8 and the only real match I have here, as far as site code, firmware and everything is an IDE drive. Should these heads work?
 Post subject: Re: Seagate IDE and SATA heads interchangeable?
PostPosted: February 1st, 2011, 19:23
Well, I went ahead and tried it anyway. I'm actually surprised that they worked. So yes, in answer to my own question, they are compatible. :lol:
PostPosted: February 2nd, 2011, 1:33
Why should that surprise you? I would have been surprised if it had not worked.
PostPosted: February 2nd, 2011, 10:40
I've always had exact matches when it comes to Seagate drives. I didn't see any reason why it wouldn't work, since everything else matched up so I went ahead and tried it. It's no big deal, just pleasantly surprised that it worked perfectly.
PostPosted: February 2nd, 2011, 19:46
The reason I say that I'm not surprised is that it wouldn't make any economic sense (at least not to me) to manufacture a SATA-only HDA and a PATA-only HDA for the same model series.
PostPosted: February 2nd, 2011, 20:16
Thank you for shring this infomration with us.
i just compelted a seagate drive with head swap and used different f/w codes and all also worked.
PostPosted: February 7th, 2011, 18:15
Also, forgot to mention, it's also not a big deal if there are 6 heads in the parts drive as opposed to 4 heads the in the patient.
Users browsing this forum: No registered users and 242 guests
