 Post subject: Wow! These guys are good.
PostPosted: February 10th, 2011, 15:24
http://www.itweb.co.za/index.php?option ... &Itemid=86
I think that we should all put their claims to the test. Every time you get a severe head crash, send it to these guys and report back here with the percentage of data they actually do recover.
 Post subject: Re: Wow! These guys are good.
PostPosted: February 10th, 2011, 15:51
South Africa eh =) I wonder if that company was set by that Nigerian prince that i helped escape from his motherland...
PostPosted: February 10th, 2011, 17:23
Can't you read? "in most cases... full recovery... 100% success rate"
BS
www.datarecoveryne.com
Last edited by harddrivespecialist on February 10th, 2011, 17:27, edited 1 time in total.
PostPosted: February 10th, 2011, 17:27
No, didn't you read they "just discovered a unique and secret method for the recovery" :roll:
PostPosted: February 10th, 2011, 17:29
must be a magic wand.
PostPosted: February 10th, 2011, 17:32
I was thinking a time machine
PostPosted: February 10th, 2011, 17:51
BS
Data recovery breakthrough on hard drives allowing for near 100% full data recovery on all damaged SATA, SAS drives
I read this as saying that they can recover NEAR 100% of the data FROM ALL damaged SATA, SAS drives.
If they were to say that could recover near 100% of the data form MOST damaged SATA, SAS drives, I might be able to swallow it, though that is still misleading, in my mind.
PostPosted: February 10th, 2011, 23:02
Doesn't pass the sniff test.
Data in the filter can't be reconstructed.
Another simple problem: suppose the physical damage is in the middle of the drive. How do you transverse the heads to the non-damaged area beyond the bad part?
http://www.datasaversllc.com
PostPosted: February 11th, 2011, 0:23
It was possible on SignalTrace, so it's not a problem
The problem is that they claim 100% success rate and all drives support which would take thousands of very skilled researchers man-hours and millions of dollars
PostPosted: February 11th, 2011, 7:26
I live in S.Africa and know this company, I use them as a supplier for drives.
What possesses them to publish a claim this unbelievable is beyond me.
"...a unique and secret method for the recovery of data from defective and failed hard drives that have bad sectors or damaged platters"
Like jono said they must have a magic reassemble-particles-from-filter-to-platter machine.
These people are probably SA's biggest data recovery company. There are a handful of other 'big players'.
Africa is where humanity was born, so it's obviously where all the new DR techniques are born as well :roll:
Data Recovery Cape Town
PostPosted: February 11th, 2011, 11:08
SignalTrace was scraped by seagate wasnt it ?
PostPosted: February 11th, 2011, 11:30
it is possible to do some of the things that they say. But to SAY it's new and revolutionary is a joke considering I have been tweeking with this since 1996-97 !
