 Post subject: 4K sector size decreasing firmware issues?
PostPosted: February 21st, 2011, 8:44
The introduction of 4K sector size means an increase in ECC size compared to 512b sectors. Does this suggest that SA modules are less likely to get corrupted, therefore drives with firmware issues should decrease and the physical/electrical problems will become the main issues to deal with?
Data Recovery Cape Town
 Post subject: Re: 4K sector size decreasing firmware issues?
PostPosted: February 21st, 2011, 12:20
Very good question . it must affect on SA modules as i think but no certainly info i got
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: February 21st, 2011, 13:01
@Nick,
In % how many FW corruption do you see in everyday work ? Here less than 7-8% (now) . The days of 2Bxxx , 2Fxxx and co. are far away.
New 4K sector format doesn't prevent FW to be corrupted, in my opinion.
Too soon to see effectively how much it will impact on failures...
PostPosted: February 21st, 2011, 16:02
Why would this be the case?
PostPosted: February 21st, 2011, 16:15
Because of:
More ECC capacity should equate to less chance of errors when reading/writing, therefore less chance of corrupted SA modules. Well that's what I would have thought, maybe I don't understand the topic enough. What do you think?
PostPosted: February 21st, 2011, 16:19
I think that ECC has little or nothing to do about FW corruption...
PostPosted: February 21st, 2011, 16:40
If SA modules are sectors like any other, how would improved ECC not help? Some insight would be good.
PostPosted: February 21st, 2011, 21:48
Agreed. Seems like a good point. However, it would help to understand how firmware corruption is caused to begin with.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 65 guests
