 Post subject: WD20EARS-00S8B1
PostPosted: February 26th, 2011, 12:13
I have a 2TB WD HD that was out of warranty that died. It initially gave two beeps and wouldn't spin up. Now the splatters spin up, I get several clicks, and then the drive spins down and repeats the process. Of course, it is not recognized in the computer. Ubuntu doesn't recognize the drive either. Are the heads dead? I take it that there is a lot more to it than finding a compatible donor drive, and swapping the heads. Can someone give me insights into the extent of the repairs that might be needed?
 Post subject: Re: WD20EARS-00S8B1
PostPosted: February 26th, 2011, 14:18
Sounds very much like a head assembly failure.
Bad news is that this is most definitely NOT a DIY job. Matching components is only part of the battle with these drives and if your data is valuable, find yourself a reputable pro in your area.
Data Recovery Ireland
PostPosted: February 26th, 2011, 14:42
Thanks. I figures as much. There is a bulldozer next door building a new home. Maybe I'll ask them to see how flat they can make the drive.
PostPosted: February 26th, 2011, 14:47
Show us some mixtures :-)
Murphy was an optimist
PostPosted: February 27th, 2011, 7:10
Sell the PCB on eBay ... before you flatten the drive.
PostPosted: February 28th, 2011, 4:06
i have this kind of donor drive in stock. look big hard drive often has problem now. WD,seagate
data recovery service[/b]
Users browsing this forum: Google [Bot] and 42 guests
