Looking for PCB for Barracuda 7200.11 and WD2500KS-00MJB0
February 25th, 2011, 8:52
DESPERATLY looking for PCBs for my two SATA HDDs with the following details:
Seagate Barracuda 7200.11 500GB
ST3500820AS
S/N: 9QM3BYAD
P/N: 9BX134-568
FW: SD81
Date Code:08405
Site Code:KRATSG
Product of Thailand
Also on the label:
WWN: 5000C5000CC537EF
STX-ST3500320AS(B)
Western Digital WD2500KS-00MJB0
S/N: WCANKD410959
Date: 01 MAR 2007
DCM: DSBACT2AAN
PCB S/N: 2060-701335-005 REV A
Sticker S/N: 2061-701335-C00 AN XC 2W21 298J 7 0002330 7332
Also can someone please tell me a safe way to replace U12 ROM without damaging it ?
Thanks a million
Re: Looking for PCB for Barracuda 7200.11 and WD2500KS-00MJB0
February 25th, 2011, 11:41
Forgot about the Seagate Baracuda PCB serial:
PCB: 100466725 REV A DLAJ-4
white sticker: 100468972 H 7839MKSM
February 27th, 2011, 6:42
WD 2060-701335-005 REVA including ROM transfer:
http://www.hdd-parts.com/20091010.html
Seagate Barracuda 7200.11 500GB ST3500820AS 100466725 PCB 500 Circuit Board with Firmware Transfer:
http://www.onepcbsolution.com/seagate-b ... nsfer.html
http://www.hdd-parts.com/10110505.html
Can you describe the failure symptoms?
If you upload detailed photos, one of us may be able to help you repair your boards, or at least confirm that the problem isn't elsewhere. For example, Seagate's 7200.11 drives have a BSY firmware bug which cannot be fixed with a board swap.
February 28th, 2011, 5:10
search" swap ROM chip for data recovery" on youtube. i have both PCB in stock. and we charge free for swap these two PCB.
