 Post subject: SMART self-tests on Maxtor DSP drives
PostPosted: October 20th, 2005, 7:30
Which module(s) I have to replace with a good one(s) in order to get my Maxtor 4D040H2 running properly its SMART self-tests?
 Post subject:
PostPosted: October 20th, 2005, 7:32
You need to look at the modules using PC3000. If the bad modules are not critical you can re-write them with known good ones.
 Post subject:
PostPosted: October 20th, 2005, 7:37
I KNOW that :x I'm asking for the position number of the relevant module(s)!!!!!!!!!!!
 Post subject:
PostPosted: October 21st, 2005, 3:44
Nice attitude! :x Not the best way to get help
Work it out yourself like I did.
:lol:
 Post subject:
PostPosted: October 24th, 2005, 12:45
Hm, 4D040H2 it's ROMULOS?
If you have wrong selfscan script - you must change selfscan script ( see you manual :wink: ) Really, to make any advice we must know what happen.
Don't have too many ROMULOS, but usually they don't give much trouble...
best regards, vi http://www.scspb.ru/pchdd/ http://pchdd.narod.ru
 Post subject:
PostPosted: October 24th, 2005, 12:50
Fu#k, miss something in question, but can't edit my answer :cry:
If we talked about SMART - well what soft you have for do the job? AFAIK acelab tools can clear SMART easyly...
 Post subject:
PostPosted: October 25th, 2005, 6:10
Yes you said right, Clear.
Repair ???????
 Post subject:
PostPosted: October 25th, 2005, 6:44
Repair ???????
Hmm... What we can have?
1. smart fail because smart modules not readable - replace not readable modules
2. smart fail because smart modules have bad contents - clear smart
3. smart fail because drive have bads or head bad - repair bads, or cut heads or throw drive to the bin
As i think we have situation Num 2, so my answer -> clear smart...
 Post subject:
PostPosted: October 31st, 2005, 8:39
Hi vi,
I'm talking about smart self test routine(s), not smart attributes! :!:
I know how to clear smart attributes...
If you use Powermax to check the drive it starts first a self-test routine. For this drive it is not possible. I tried also MHDD/SMART Test/ 0,1,2 - all fail.
Users browsing this forum: No registered users and 357 guests
