February 27th, 2011, 8:02
I have an ES2 ST3250310NS HP drive with HPG1 firmware. It works but is invisible in bios and system.
I checked it with the terminal and the "standard ES2 solutions" don't work (even the one with shorting reading channel).
I've read this post
st3250310ns-hpg1-firmware-problem-t14598.htmlIs there anything I can do to unlock it in terminal ?
February 28th, 2011, 8:22
Have you searched russian forums ?
March 1st, 2011, 6:19
There are several PCB versions for ES2. Have you identified the correct solution (localization of read channel)?
March 4th, 2011, 7:04
I've used correct solution.
Do seagate drives have safe mode like WD ?
March 8th, 2011, 4:50
Is there a way to "reset" the drive ?
