microsoft exchange edb file corrupted
March 3rd, 2011, 21:56
hi there,
i have edb file more than 100GB in size, and its corrupted.
I already try using Kernel and Enstella but its still said corrupted and result was nothing.
Anyone can help ? I heard Dr Kieves can do this ?
Re: microsoft exchange edb file corrupted
March 4th, 2011, 4:15
Are you trying to repair the db or extract data from it?
Do you have the log files? I don't believe that Kernel uses the logs, which almost always results in missing data anyway.
March 4th, 2011, 4:28
dstekno wrote:hi there,
:shock: Where did you heard this ? :)
What happend with your file? Was it recovered with some soft ?
Why it is corrupted? Are you sure that this file has need data inside? :)
March 4th, 2011, 23:09
Might try the eseutil that come with the appropriate version of MS exchange server. Its a bit tricky, but that tool is pretty good at reassembling the db. Also might look at some "forensic" tools such as Paraben Network Email examiner that can read from a raw db file....
March 5th, 2011, 12:06
If using ESEUTIL, and there is no reason not to, as with anything else: Run it on a copy, not the original db. As with many Microsoft utilities the result can occasionally be worse than the original problem.
