 Post subject: ST3320620A
PostPosted: March 7th, 2011, 11:45
Could anyone give me a starting point on this please? ST3320620A 7200.10, fw: 3.AAF, sn: 5QF3CB22
Detected in PC3K correctly but endless output in terminal of below:
Reset
4096k x 32 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
Buzz HM SFI
(P)PATA Reset
Master
AT Er 00 Nwt Er 43 RdWr 1ce8d.03.0180
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f29ff7 b6 97f29ff7.3.640 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 01ce8d.03.0180
CE Log ErrCode=43 LBA=2466f118 Type=5 Add To Pending 2466f118
$$$SFI
AMR
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 1ce8d.03.017f
Niwot: 2466ef98 14 2466ef98.2.190 0180 3642 0180 0000
Spare of 2466f117 failed
AT Er 00 Nwt Er 43 RdWr 1ce8d.03.0181
Niwot: 9ff79ff7 b6 9ff79ff7.3.640 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 01ce8d.03.0181
CE Log ErrCode=43 LBA=2466f119 Type=5 Add To Pending 2466f119
$$$SFI
AMR
AT Er 00 Nwt Er 47 RdWr 1ce8d.03.0182
DiskAccess ReadSector EC=47 at 01ce8d.03.0182
CE Log ErrCode=47 LBA=2466f11a Type=5 Add To Pending 2466f11a
$$$SFI
AMR
AT Er 00 Nwt Er 43 RdWr 1ce8d.03.0183
DiskAccess ReadSector EC=43 at 01ce8d.03.0183
CE Log ErrCode=43 LBA=2466f11b Type=5 Add To Pending 2466f11b
$$$SFI
AMR
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 1ce8d.03.0184
Niwot: 2466f11c 14 2466f11c.2.190 01d0 3642 01d0 0000
Spare of 2466f11c failed
Data Recovery Cape Town
 Post subject: Re: ST3320620A
PostPosted: March 7th, 2011, 11:55
You have many pending sectors.
www.datarecoveryne.com
PostPosted: March 7th, 2011, 16:58
Also could be a head issue because of :
$$$SFI
AMR
PostPosted: March 8th, 2011, 3:02
I can see the partition and folder structure on the root in data extractor, but it takes about 10mins to come up because it's still busy and in a constant cycle of trying to read that module/s (or whatever it is doing). The fact that the drive inits and I can view folder structure gives me hope.
PostPosted: March 8th, 2011, 4:04
do u get a lot of software/hardware reset while viewing folders in DE?
PostPosted: March 8th, 2011, 4:09
Yes, I do. When I attempt to work with the folders it goes BSY but does eventually after a few minutes, respond. So if I try and expand a folder in DE, it goes BSY, I wait about 5mins, then the folder expands and I can see contents. When I tried to copy a selected folder to an external drive it gave lots of software/hardware resets.
PostPosted: March 8th, 2011, 4:41
pm sent
PostPosted: March 8th, 2011, 5:10
Thanks E9, will give it a go and report back.
PostPosted: March 9th, 2011, 5:41
Update on this, the problem has been resolved.
It was a firmware issue. Had to use the antipending solution, used a LDR. Am now getting access to data at normal speed and imaging to another drive.
PostPosted: November 7th, 2011, 8:01
I would like to publicly thank Nick_CT and hddguy for helping me with this, i had a similar problem and has now been resolved.
Cheers!
PostPosted: November 7th, 2011, 8:45
:beer: :beer:
PostPosted: November 7th, 2011, 10:29
i think u can also image these drives in DDI with the option of initialize read on. A bit slow though...
Users browsing this forum: No registered users and 80 guests
