 Post subject: WD My Studio zero partitions
PostPosted: March 15th, 2011, 6:36
1TB WD10EADS
DDI no probs (reverse to be safe)
no partition info in Rstudio/UFS
data visible in winhex - unpartitioned space
not encrypted apparently
firmware prob?
ta
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: WD My Studio zero partitions
PostPosted: March 15th, 2011, 7:16
is it External Drive if yes then check External casing Board it might Encrypted.
PostPosted: March 15th, 2011, 8:04
@buster80: I agree with microsoftengineer that one possible (likely?) reason for the behaviour you describe, is that there is more to this story... ;)
Here are some brief specific questions:
buster80 wrote:
1TB WD10EADS
What's the history of the drive? Where did it come from (enclosure or not)? What's the original reported fault?
What does LBA 0 actually look like? Recognisable MBR code or not?
What does LBA 1 look like? All zeros? Or a repeating 16 byte pattern? Or something else?
But is it recognisable data (text / jpg / etc.)? Or does it appear to be random (and therefore possibly encrypted)?
What leads you to that conclusion?
You might find this thread interesting, if it turns out that this drive is from an encrypted enclosure, as it shows some of the behaviour you seem to be reporting e.g. no valid partiton table on the bare drive (because it's encrypted by the enclosure):
http://forum.hddguru.com/disk-with-sata-usb-adapter-remove-virtual-rom-t18492-20.html
PostPosted: March 15th, 2011, 8:13
yea looks encrypted, getting the original caddy in 1 hour
thanks for all your help
andy
bingo, cheers vulcan
p.s u too pcimage ;)
PostPosted: March 15th, 2011, 8:24
No problem :-)
PostPosted: March 15th, 2011, 8:25
No problem :-)
PostPosted: March 15th, 2011, 16:21
this is the beauty of this forum.
RAID/Server Recovery
PostPosted: March 15th, 2011, 16:36
True that :)
PostPosted: March 15th, 2011, 16:57
You get it sorted?
PostPosted: March 15th, 2011, 17:22
Works in the case, stays mounted few seconds. Going to look at it again AM
PostPosted: March 20th, 2011, 9:29
Drive is sure crypted
PostPosted: March 20th, 2011, 9:31
yip, worked in the case. Not that bad, r-studio did the trick :)
Users browsing this forum: Phamthanhktv and 67 guests
