 Post subject: Seagate 7200.10 dead
PostPosted: March 18th, 2011, 4:14
Have a 7200.10 drive. Came from a Dell with a dead MB. Drive powered up once out of the machine, but now it is dead. Won't power on. Data is worth the effort.
PCB swap from PCB Solutions web site? Do I need a chip swap as well?
Model: ST3320620AS
P/N: 9BJ14G-033
Firmware: 3.ADG
Site Code: WU
Capacity: 320GB
Main Chip #: 100404225
 Post subject: Re: Seagate 7200.10 dead
PostPosted: March 18th, 2011, 5:02
Post a pic of the PCB, component side up.
Data Recovery Cape Town
PostPosted: March 18th, 2011, 13:52
PostPosted: March 18th, 2011, 14:05
It seems that the board it's a little brown.
Post a picture of the other side.
ACELab partner
PostPosted: March 18th, 2011, 15:36
Uploaded with ImageShack.us
PostPosted: March 18th, 2011, 18:10
If the HDD won't even spin up then you can try testing the 2 components in red here:
http://i54.tinypic.com/2z4wbr4.jpg
If they measure 0 ohms or very close to it then you can try and remove them and try and power up the HDD. Use side cutters or a heat gun to remove them. The HDD has no power protection once they are removed.
There are obviously risks involved.
Search for 'TVS' in this forum for more info on it. If that doesn't work then something more important on the PCB is fried, like the MCU or something else.
PostPosted: March 18th, 2011, 18:53
The serial flash memory IC is the 8-pin chip (Atmel) in the bottom right corner of your photo. It should have a "25" in its part number.
PostPosted: March 19th, 2011, 0:21
PostPosted: March 19th, 2011, 0:24
TVS is a hard term to search for. Can you expand on that term?
PostPosted: March 19th, 2011, 1:40
http://www.google.com/search?q=%22ST332 ... ddguru.com
PostPosted: March 19th, 2011, 14:26
One of these has 65Kohms, the other is cooked I think at 1.9ohms. I'm using an external drive caddy to test this disk. When I apply power the power LED on the drive caddy immediately goes out. I'm worried this drive has a short somewhere.....
I have another 7200.10 320G drive that works slightly, but doesn't model/date code. Can I at least use that PCB to test this drive and see if it will spin up? Or is that a bad idea.....
Users browsing this forum: No registered users and 61 guests
