March 20th, 2011, 14:54
help me , how i can change of my hdd serial number (id) the hdd is one hitachi 60gb , pls help me to change the serial number .
March 21st, 2011, 4:08
It is easy to do with proper tools , but explain what for you need that ? May be your questions have another way to solve?
March 21st, 2011, 5:52
DR-Kiev wrote:It is easy to do with proper tools , but explain what for you need that ? May be your questions have another way to solve?
i need to change the sn for one soft .. the soft is registered don't start only with one serial number , i know this sn , the hdd is one toshiba .. and my hdd is same .. toshiba
i remowed the eprom from hdd and readed the eprom .. and i don-t know how is locate the serial number
the eprom ic is 93c56
reded with willem eprom programmer
i readed in two metod on 8 bit and in the 16 bit mode this eprom , i don-t know what is ok
the eprom files
- Attachments
- hdd_eprom.rar
- eprom
- (705 Bytes) Downloaded 628 times
March 22nd, 2011, 6:20
i writed the model wrong .. the model is hitachi travelstar , pn- 08k0634 , sn -k3g6bbbk
March 22nd, 2011, 6:47
Hi
No...What you have read in the programmer is the NV-RAM which has nothing to do with serial number...The serial number is stored somewhere on the platters in some modules..Not so easy to modify without proper tools.
So you will need to find someone who have the right tools to do it.
Rgds.
March 22nd, 2011, 8:17
i need to change the sn for one soft .. the soft is registered don't start only with one serial number Based on my experience on this issue i can tel you that most protection goes for the
partition Vol. SN.not hdd SN
March 22nd, 2011, 8:32
einstein9 wrote:i need to change the sn for one soft .. the soft is registered don't start only with one serial number Based on my experience on this issue i can tel you that most protection goes for the
the volume serial nr. i changed and not work , don't start the soft
March 22nd, 2011, 8:48
It depends on sw. ! Hdd s/n is used too on many protection scheme.
March 22nd, 2011, 15:46
ccc wrote:Hi
Rgds.
Actually, SN is stored in NV-RAM as well as in service area on disk surface.
March 23rd, 2011, 2:22
msurgeon wrote:ccc wrote:Hi
Rgds.
On ATMR series?...I did't see it...Anyway from his point of view it's useless...He does not have the tools to modify NV-RAM/checksum or SA modules.
Rgds
March 23rd, 2011, 14:15
ccc wrote:On ATMR series?...I did't see it...Anyway from his point of view it's useless...He does not have the tools to modify NV-RAM/checksum or SA modules.
Rgds
No, you're right, not on ATMR series but I didn't notice that was the case here.
March 24th, 2011, 9:54
the question is simple possible or not without pc3000 to change my hdd id ?
