Post new topic Reply to topic  [ 86 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: PCB 0J35276 BA5145B for WD80EZZX-11CSGA0
PostPosted: May 10th, 2019, 10:12
i've this hard drive with faulty pcb:
WD80EZZX-11CSGA0
P/N: 2W10100
PCB Revision: 0A90439
PCB Sticker: 0J35276 BA5145B
this is an HGST helium drive, pcb has damaged SMOOTH L7229 chip.
I can't find this pcb anywhere, could any of you kindly lend me this PCB or at least help me to find it?
Thank you.
My firmware database:
 Post subject: Re: PCB 0J35276 BA5145B for WD80EZZX-11CSGA0
PostPosted: May 10th, 2019, 17:12
https://www.ebay.com/itm/HGST-HUH728080ALE600-HDD-PCB-Logic-Board-Board-number-006-0A90439-0J35276-/253814014166
PostPosted: May 10th, 2019, 17:21
Thank you Frank :wink:
PostPosted: May 10th, 2019, 17:37
Ohh, that user on ebay has a lot of bad feedbacks :?
I also did try to search this pcb on ebay by inserting "0J35276" and "BA5145B" as key words, it didn't show me any result.
Without your direct link i wouldn't have found it, but i want to give a try.
Thank you again.
PostPosted: May 10th, 2019, 18:41
Yes it was me, i know i'm risking with this guy but as i said i wanna give a try.
I can't find that board anywhere else.
PostPosted: May 10th, 2019, 19:07
I'm curious. Where is the damage to the SMOOTH chip? Are either of the TVS diodes shorted?
PostPosted: May 10th, 2019, 19:09
No Frank, TVS diodes are not shorted.
The drive just doesn't spin, it's completely silent.
PostPosted: May 10th, 2019, 20:52
You might like to measure some voltage test points:
http://www.hddoracle.com/viewtopic.php?f=21&t=2549&p=20304&hilit=OA90439#p20304
I expect that you would have checked that PUIS was not enabled ...
PostPosted: May 11th, 2019, 5:20
This hard drive came here with no power on issue (it was completely silent).
I thought pcb was faulty so i did some test...
First i did power on under MRT, ID was correct and DRD + DSC registers where green.
Then i started to do some signal checking with multimeter, see pics:
After that i power off and went to have lunch, when i came back to continue with further test, smooth chip smoked right away when i powered on. :(
PostPosted: May 11th, 2019, 7:51
DonorDrives has a drive listed - http://www.donordrives.com/catalogsearc ... ZX-11CSGA0
PostPosted: May 11th, 2019, 9:47
I know but is too expensive the entire drive, customer doesn't want to spend so much.
If i can recover just with pcb swap that's great, otherwise he doesn't care as much about data inside.
PostPosted: May 12th, 2019, 6:30
Spildit wrote:
Some of those He filled drives will not spin if the sensors do detect that He is gone ...
How do i know if this drive is one of those?
What can i do for recovering data if sensor already detect that helium is gone?
P.S.
First of all, at this point, i've to replace pcb because now it's sure that is damaged. I don't know why this happened!
PostPosted: May 13th, 2019, 4:49
There is a great chance it is spindel stuck issue
Angel Data Recovery
PostPosted: May 13th, 2019, 14:03
If pcb works good, in case of spindle stuck, should i be able to listen a bip sound with a hear next to the drive?
PostPosted: May 16th, 2019, 3:22
I received 2 of these this past week. WD80EZZX-11CSGA0. In both cases there was no spin up. Was able to recover both using a working PCB(ROM swap). PC-3000 does't recognize the family so i had to just pick another family from the WD 3.5 group. No issues in DE.
PostPosted: May 16th, 2019, 4:07
Protech wrote:
I received 2 of these this past week. WD80EZZX-11CSGA0. … PC-3000 does't recognize the family so i had to just pick another family from the WD 3.5 group.
According to the OP, the drive is a HGST helium model, so which WD group did you select?
PostPosted: May 20th, 2019, 23:50
I used Giant2. like I said it was a random pick. No particular reasoning behind it. Since PC-3000 doesn't support the drives you cant work with SA yet.
PostPosted: May 21st, 2019, 2:18
Could it be that a stuck spindle is the reason that the motor controller failed?
PostPosted: May 21st, 2019, 6:28
We had a 16TB My Book Duo with 2 of those 8TB WD Helium HDDs in. Both no spin.
The techs at the IT company it went to first took the drives out and tested them. They said they were not spinning as well, but not sure if that happened naturally within the external enclosure itself or maybe it was a mess up during testing.
No visual physical signs of any burns on the PCBs.
Some brief preliminary voltage testing checked out fine. Nothing apparent being suspicious.
Good donor drives we ordered spun right up without issues in case a PUIS or anything weird was configured on them.
Replaced PCBs on each drive with ROM swap and got the patient drives working again.
https://www.datarecoveryguru.com/blog/2 ... ard-drives
PostPosted: May 21st, 2019, 16:49
DATARECOVERY GURU wrote:
Well, for starters, both of these NASWare ready model hard drives strangely sustained electronic failures. Upon testing each HDD at the time for file recovery, neither drive was spinning when powering on.
With that in mind, parts were ordered to repair the PCB on each hard disk drive, as well as sourcing an entirely new WD casing.
Was a new enclosure really necessary? Did you test the original bridge PCB?
The next step in the data recovery process was to inspect the SMART attributes on each drive using advanced data recovery software.
There is no need for "advanced" software. Just about any freeware SMART tool will do this.
Finally, the data recovery process from this external drive went as expected, mounting the Mac volume on a MacBook Pro, access the 7.1TB worth of files and extract them out to a brand new Seagate USB external drive.
This type of file recovery requires advanced data recovery software and hardware knowledge and tools, including a substantial investment of over $600 in parts alone.
So you mounted the customer's data on a Mac OS, and then copied the files to an external drive? Where did the "advanced" software and "advanced" hardware knowledge and "advanced" tools come into the picture?
ISTM that this was potentially a very simple DIY job.
Users browsing this forum: Google [Bot] and 60 guests
