 Post subject: 7200.11 0mb
PostPosted: March 30th, 2011, 4:21
hi all
i have a drive 7200.11 st 3750630as f/w De 12
the drive initially had an issue of BSY, once this was resolved the drive straight away shows an issue of 0mb
any attempts to solve the 0mb ends up in the error below
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8
Error 1008 DETSEC 0000500D
User Partition Format Failed - Elapsed Time 0 mins 00 secs
R/W Sense 00000002, R/W Error 00000084, File Error 00001002
Blk Addr 01080001, Blk Addr Type D0, Cyl 00010000, Hd FE
has anyone come accross this and got a solution for it.
thank you
 Post subject: Re: 7200.11 0mb
PostPosted: March 30th, 2011, 6:05
what pro. Tools you use....................
PostPosted: March 31st, 2011, 11:26
disconnect the PCB from the HDD, and use the connect the PCB only, power on and post the log here
did u try isolating the motor method with ur result log u provided? or how
explain what you did here in details.
PostPosted: March 31st, 2011, 11:30
Correct me if I'm wrong, but isolating the PCB is for the LED error, not the 0 capacity error. Also, I don't think that you'll get much of a log with the PCB by itself.
Offhand, I'd suspect a bad or weak head, and would try a heads test straight away.
http://www.datasaversllc.com
PostPosted: March 31st, 2011, 15:59
jono-ats I Agree with you on this which might be bad heads, but i had such similar case and tried the Isolating method and worked with me, this was with 1TB Max-SG hdd.
AM using the SD-SG with Seagate most of the time, and most of the time again, problems are solved with the terminal most of the features of SD-SG are not used.
let`s wait for his reply on this and see.
thnx man
PostPosted: March 31st, 2011, 16:58
How to Test Seagate Drives' Heads for HDD Repair:
http://www.datarecoverytools.co.uk/2011 ... dd-repair/
PostPosted: March 31st, 2011, 17:33
fzabkar this heads test is not for 7200.11
ZeBong
" Россия еще раз"
PostPosted: March 31st, 2011, 18:24
hi all
thank you for the answers and replies so far.
to answer some of the questions, tool used is pc3000, Atola
to resolve the bsy issue i used the pc3000, this repaired the issue of the drive being bsy
once the drive was restarted the drive showed 0mb, here i tried the solution from pc3000 ehihc has worked on many many occassions but failed on ths one.
i have not tried removng the bosrd to test with the board isolated. i did think about manye a weak head but heads test with pc3000 shows to be ok
i started suspecting mabye a issue with pcb so i am thinking of swapping pcb to test and see what results i get here.
so far this is where i am up to on it.
i have been advised that this is not a recoverable error currently and to mabye try in the future, but i really want to try and work out what is happening with this drive.
thank you
Users browsing this forum: No registered users and 98 guests
