 Post subject: I have a problem with the PCB of Seagate HDD. Help me!
PostPosted: April 9th, 2011, 11:12
Hello everyone,
My English is not good.
There are few parts burned, but I do not know what it is.
Seagate Barracuda 7200.12 500GB
S/N: 5VM4DC8X
Date Code: 10176
Expect people to help.
Thank you very much!
 Post subject: Re: I have a problem with the PCB of Seagate HDD. Help me!
PostPosted: April 9th, 2011, 17:00
looks pretty cooked :-(
Probably need new PCB and ROM transfer.
PostPosted: April 11th, 2011, 19:15
The board has suffered an overvoltage on both the +5V and +12V supplies. What did you do?
In most cases the damage caused by an overvoltage will be restricted to shorted TVS diodes. However, in your case there are inductors which have also been burnt. The usual solution is to snip the damaged TVS diodes with flush cutters, and replace the inductors with wire links.
If the above fails, then you will need to transfer the serial flash EEPROM to your donor board. Some board suppliers offer a transfer service for US$10, otherwise your local TV repair shop should be able to do it.
The following photos should help you identify the affected components:
http://www.users.on.net/~fzabkar/HDD/ST ... 2V_TVS.jpg
http://www.users.on.net/~fzabkar/HDD/ST ... uctors.jpg
http://www.users.on.net/~fzabkar/HDD/ST ... 5V_TVS.jpg
Users browsing this forum: Google [Bot] and 67 guests
