 Post subject: Looking for Samsung 1.8" SATA SSD Adapter / Connector
PostPosted: April 18th, 2011, 20:28
I'm trying to find a standard SATA adapter that connect to a Samsung 1.8" SATA SSD drive, removed from a MacAir notebook.
The drive is a bit peculiar in that it has a 24 pin ZIF connector, and requires 3.3 V.
Connector specs are as follows:
Pin 2,3 : 3.3V
Pin 8: DAS (Device Active Signal)
Pin 11,12: A+ /A- Differential Signal Pair A
Pin 14,15: B- /B+ Differential Signal Pair B
Pin 1,4,7,9,10,13,16,17,24 : GND
I'm sure that I can rig up something that will work with a soldering iron, but I'd prefer an adapter.
Anyone seen one that is commercially available?
Jon
http://www.datasaversllc.com
 Post subject: Re: Looking for Samsung 1.8" SATA SSD Adapter / Connector
PostPosted: April 18th, 2011, 20:59
It's not one of those new LIF connections is it? If so, we use these: http://www.mydigitaldiscount.com/SPD/ru ... 043844.jsp
In stock here: http://www.memoryc.com/storageproducts/ ... drive.html
PostPosted: April 18th, 2011, 21:27
I believe that is the correct interface, only problem being that it is USB.
Jon, I was not able to find anything and just soldered one together out of an old IDE zif adapter
PostPosted: April 19th, 2011, 7:37
Thanks, y'all.
I have one of the ZIF to USB adapters.
Looks like a soldering iron, microscope, and wire-wrap wire are in my future . . .
:D
PostPosted: April 19th, 2011, 10:58
Agent,
Your product will work fine for this application.
THX!
Jon
Users browsing this forum: No registered users and 84 guests
cron
