 Post subject: (TVS) Identification Help on a WD PCB.
PostPosted: April 16th, 2011, 17:05
I accidentally shorted the TVS on a couple of HDDs and found this site that showed me how to temporarily locate and cut the TVS to retrieve the data onto a brand new drive. I didn't realize that the power supply I was using was damaging the drives so I kept using it on different drives trying to figure out why the drives weren't working..... Long story short I have one WD 3.5" that I can't find the TVS.....
(29 NOV. 2002)
S/N: WMA8C3315613
MDL: WD1200JB-75CRA0
DCM: DSEHNA2AH
Sticker: 2061-001102-301C
Board: 2060-001102-003 REV. A
also a 160GB 2.5" WD laptop drive which I can't find the TVS for either.
Can anyone help me find these so I can get my data off these drives?
Sorry I don't have any pictures at this time but if I need to I can borrow a camera from someone to upload here. Thanks for any help. :)
 Post subject: Re: (TVS) Identification Help on a WD PCB.
PostPosted: April 16th, 2011, 18:05
You may be able to use a scanner.
Anyway, if this is your board, then it has no TVS diodes:
http://76.my/Malaysia/hdd-logic-board-p ... tech@5.jpg
Location D3 was probably reserved for a 5V TVS diode. :-(
BTW, which supply rail was affected, +5V or +12V? I'm assuming it was the +5V supply, since your laptop drive wouldn't use the +12V rail.
PostPosted: April 16th, 2011, 18:28
Am I just S.O.L. on these two drives then? On the laptop drive I see a D1 and D2.... but those aren't near the the power connectors like the 3.5" drive that I fixed.
PostPosted: April 16th, 2011, 18:29
Oh I almost forgot, yes that is the board.
PostPosted: April 17th, 2011, 2:02
Am I just out of luck on my other 3.5" drive and the 2.5" drive?
PostPosted: April 18th, 2011, 5:34
It seems that way.
Data Recovery Cape Town
PostPosted: April 19th, 2011, 4:43
There is a similar board in this thread:
easy-faultdiagnostic-troubleshooting-must-try-t12319.html
I don't know if a straight board swap will work, but you could at least measure the various voltages, if only as a post mortem exercise.
As for your 2.5" drive, if you can't provide a photo, then how about a model number, or a Google image?
PostPosted: April 20th, 2011, 20:31
Fzabkar the board on the 2.5" is....
2060-701450-011 Rev A
sticker:2061-701450-Z00 AF
It is a WD Scorpio WD1600BEV
PostPosted: April 25th, 2011, 4:51
If this is your board, then I don't see any TVS diodes:
http://i.ebayimg.com/18/!BtPWjWwCGk~$(K ... Dg~~_3.JPG
Worse still, there is no chip at U12, which means that the "adaptive" data are internal to the Marvell MCU.
If you have a multimeter, you could always measure the voltages at the +3.3V and +1.2V test points.
PostPosted: April 26th, 2011, 7:15
It depends on who services the drive to get data even with (= without) totally blown PCB...
