SEAGATE MOMENTUS
February 1st, 2010, 13:49
Hi to all,
Have this seagate with this in terminal.
Can be BAD HEADS or scratch platter ?
Interface task reset
4096k x 16 buffer detected
MERC2 - 1_Disk 0.02 12-
Buzz - 22-05 16:43
Head Mask 03,01 - Head Mask 03,05 - Head Mask 03,06 - Switch to full int.
Spin Ready
Dwell Cyl - 084F/04CD/0000
$Head Mask 03,07 - Switch to full int.
Spin Ready
$Head Mask 03,07 - Head Mask 03,08 - Switch to full int.
$Head Mask 03,08 - Head Mask 03,09 - Switch to full int.
$Head Mask 03,09 - Head Mask 03,0A - Switch to full int.
Spin Ready
$Head Mask 03,0B - Switch to full int.
Spin Ready
$Head Mask 03,0B - Head Mask 03,0C - Switch to full int.
$Head Mask 03,0C - Head Mask 03,0D - Switch to full int.
$Head Mask 03,0D - Head Mask 03,0E - Switch to full int.
$Head Mask 03,0E - Head Mask 03,0F - Switch to full int.
$Head Mask 03,10 - Switch to full int.
Spin Ready
$Switch to full int.
AM Reacquired
AM Reacquired
$ AM Reacquired
Head Mask 03,11 - Switch to full int.
Spin Ready
AM Reacquired
$Head Mask 03,12 - Switch to full int.
Spin Ready
$Head Mask 03,12 - Head Mask 03,13 - Switch to full int.
$Head Mask 03,13 - Head Mask 03,14 - Switch to full int.
$Head Mask 03,14 - Head Mask 03,15 - Switch to full int.
$Head Mask 03,15 - Head Mask 03,16 - Switch to full int.
$Head Mask 03,17 - Switch to full int.
Spin Ready
$Head Mask 03,18 - Switch to full int.
Spin Ready
$Head Mask 03,19 - Switch to full int.
Spin Ready
$Head Mask 03,19 - Head Mask 03,1A - Switch to full int.
$Head Mask 03,1A - Head Mask 03,1B - Switch to full int.
Spin Ready
$Head Mask 03,1B - Head Mask 03,1C - Switch to full int.
$Head Mask 03,1C - Head Mask 03,1D - Switch to full int.
$Head Mask 03,1E - Switch to full int.
$Head Mask 03,1E - Head Mask 03,1F - Switch to full int.
$Head Mask 03,1F - Head Mask 03,20 - Switch to full int.
$Head Mask 03,20 - Head Mask 03,21 - Switch to full int.
$Head Mask 03,21 -
Re: SEAGATE MOMENTUS
February 1st, 2010, 16:06
5400.2 it looks like?
Probably heads, check for damage, these ones like to hide the damage on lower platters...ugh.
February 1st, 2010, 16:21
Yes, I would think heads or MD. I see that's a MERC2, is it a FW 7.01 with Apple logo?
February 1st, 2010, 16:24
Or 3.CAE?
Bet it's Chinese though!
February 2nd, 2010, 6:59
the disk is this one :
Momentus 5400.2
60GB
S T 9 6 8 1 2 A S
FW.701
Singapore
i will open it and look at the platte 0
February 2nd, 2010, 9:42
Surprise surprise!
February 2nd, 2010, 10:10
there is another forum you could pose this question on ;)
February 2nd, 2010, 14:15
I do not know witch one are you talking about ;) but anyway here it goes the heads in pictures
Also the Platte 1 have a very small scratch in the park zone
Anyone knows witch head in this model read the SA the H0 or the H1 or both ?
May 13th, 2011, 9:39
zebong wrote:I do not know witch one are you talking about ;) but anyway here it goes the heads in pictures
I have the same:
Came out of Mac M1n1:
Momentus 5400.2
ST96812AS
FW: 7.01
SINGAPORE
60GB
MERC2
The Patient was clicking.
I got a working donor, did a Head swap.
Upon doing the head swap I discover 2 micro-Donuts:
1: at Sector 0
2: about 80% out
Looks like Saturn.
The Heads didn't break off.. but Head 1 (the top) looks like if lost a few layers and started to dig in... for coal.
After Head swap:
No Click, but wont come out of busy.
Terminal:
Buzz - 22-05 16:43
I don't think the donor's Heads went bad. If they did go bad, I imagine it would start clicking. which it is not clicking.
The heads are not stuck either..
Anyone know a way around this one?
Hot swap? Hammer time?
May 13th, 2011, 10:05
I vote hammer time :lol:
May 14th, 2011, 3:35
I have to find my baggy pants first.. 8)
May 18th, 2011, 20:17
Here's an interesting Predicament.
The patient Clicked.
The donor worked.
I did a Head swap.
The patient now doesn't load or move the new (Donor's) HDA on to the Platters.
The HDA just sits in the parked position. The coil has continuity.
I put the Donor HDA back to the DONOR and the DONOR doesn't move the HDA at all, ether.
I checked the Gasket. I even removed the Gasket. Nothing.
The DONOR sits in BUSY state. No Clickee; No Movee.. It just spins up... WTF?
I want to hold off on the hammer time.. until later.. :?
