 Post subject: need pcb for Seagate Momentus 5400.6 160GB
PostPosted: May 17th, 2011, 17:50
Soundscu, I didn't see your photo. Could you provide a link to it?
BTW, the fact that the drive spins up would suggest that the board is most probably OK, in which case you would have wasted your money on a replacement. However, I'm not a data recovery guy, just someone trying to help.
Soundscu wrote:
I'm hoping somebody has a pcb for a Seagate Momentus 5400.6 160GB HDD. This is not for high-value data recovery, so I'm looking to spend less than the cost of a new drive, including shipping, etc.
The exact drive modle is ST9160314AS, it came out of a cheap Gateway netbook.
Thanks for your help!
Jim
Can you describe the failure symptom?
If you upload a detailed photo, one of us may be able to help you repair your board, or at least confirm that the problem isn't elsewhere.
Soundscu wrote:
When connected to a PC, the drive spins up -- I can hear the whir and feel the vibration in the frame. The PC does not recognize the presence of the drive at all.
Jim
 Post subject: Re: need pcb for Seagate Momentus 5400.6 160GB
PostPosted: May 18th, 2011, 11:06
Banned User
looks like heads are stuck to platters or motor failed
banned user
PostPosted: May 18th, 2011, 11:08
Banned User
http://cgi.ebay.co.uk/Seagate-ST9160314 ... 1797wt_905
banned user
PostPosted: May 18th, 2011, 12:01
PostPosted: May 18th, 2011, 16:14
Banned User
drc
you never had a drive where motor was not having enough power to spin it up ?
banned user
PostPosted: May 18th, 2011, 17:33
IMO "spins up" is not compatible with "heads are stuck to platters or motor failed"
Users browsing this forum: Google [Bot], Majestic-12 [Bot], michael chiklis and 224 guests
