 Post subject: WD4000AAJS - bad head swap?
PostPosted: May 19th, 2011, 22:49
I was able to image about 60% of the drive, but there were huge chunks that would not image and caused the drive to go busy. I swapped the heads and hooked up the drive to Atola to get the rest. However, now the drive is quietly clicking 3 times and then powering down. I am using the DRT alignment tool, but can't seem to find the sweet spot. My questions are:
1. Does this series drive have huge alignment issues - Tornado 2R series I believe?
2. Is there a way to determine if the head swap went ok, or if I just have to work with the alignment jig more?
Shawn
 Post subject: Re: WD4000AAJS - bad head swap?
PostPosted: May 19th, 2011, 23:20
This does not really have special alignment issues, like most of the pre-royals do. Clicking and powering down means that one or more heads is bad, or is a mismatch.
http://www.datasaversllc.com
PostPosted: May 19th, 2011, 23:45
Thats what I was afraid of. The donor appears to be a good match, both match on full model/firmware data, DCM's are:
DHRCNT2MHB
DHRNHT2AHB
Looks like I will be sourcing another donor and getting the 'right' head tool.
PostPosted: May 23rd, 2011, 23:11
Update - I switched the original heads back onto the patient and the drive became ready and let me image the rest of the drive out (actually about 98%).
I believe the donor drive was a good match and I just botched the swap somehow. However, the interesting thing is that I was able to image the rest of the drive AFTER putting the original heads back on the original drive. As Jon indicated, there were no alignment issues.
