 Post subject: help unable to open the volume because mft files is outside
PostPosted: May 26th, 2011, 4:44
hi can anyone help us i bought a brand new 2tb loaded it up to my home cinema system full of my moves and shows.
for some reason i turn it on nothing at all
so i ran partition doctor and it said fix boot error
tried to repair it no lucky
so i ran r-studio and i mounted the drive
but when i try to get my files im getting the following error below.
unable to open the volume because mft files is outside disk bounds
the worse thing is that i can see the partition but that about it
anyone recommend a good imager or a program that keeps the file tree in order
that a lot of movies and tv shows to sort out with out this :(
thanks all
 Post subject: Re: help unable to open the volume because mft files is outside
PostPosted: May 26th, 2011, 10:39
Did you run a detailed scan in R-Studio?
PostPosted: May 26th, 2011, 10:50
Curious, apart from logical any other diagnostic done?
PostPosted: May 26th, 2011, 12:31
Could it be HPA?
PostPosted: May 26th, 2011, 15:21
You can diagnose the drive in Dmde which also has a repair option but make sure you back up before making changes or better still make a clone image.
Or you can use Easeus which also has tools to check partitions and carry out repairs.
Good thing, both tools are free!
PostPosted: May 26th, 2011, 16:49
This can be bad or less bad. You may have a bad head, resulting in excruciatingly slow read/write meaning 300 days to image disk etc. You also may have an SA issue.
See what TestDisk says (don't write the new partition), and see what Hard Disk Sentinel says about the bad sector count and S.M.A.R.T. errors. If there is an abundance of exceptions, dying disk.
Otherwise scan it with getdataback or UFS
PostPosted: May 26th, 2011, 16:52
i ran mhdd and it comes back there nothing wrong with the drive at all
servo no errors etc
i also ran hirens bootsdisk and this came back no issue
i did a full scan with r-studio and it came back with the files
but only the avi files showing and no yellow folder names at all of each movies
also tried getdata back no luck at all with the files
not sure why it gone like this but its screwed up with that error a corrupt mft
the drive is brand new never been dropped or any issue until now
the drive is partition to ntfs and not ufs format ??
just checked the log and it says hppf (ntfs)
anyone know what this might be
any other options
PostPosted: May 26th, 2011, 17:06
out of curiosity, were the video files listed in R-Studio scan good? Were they usable or could you do a preview?
PostPosted: May 27th, 2011, 1:17
yep files play ok i recovered about 100 avi and they play perfect.
but as they where in a yellow folder with the name of the movie
it just recovered the avi files only and not the whole folder name :(
so i think the options is to recovery everything as normal and relabel each one
its going to take some time for sure.
PostPosted: May 28th, 2011, 9:44
just a update on this weird problem it looks like mirror damaged on the drive
this would explain the mft corruptions.
media surface checks ok
but now its stays sector 209011725 read error
im doing the recovery now i have to place all my movies back in the correct folders.
up to know it doing the recovery.
seagate are crap :(
PostPosted: May 28th, 2011, 11:45
What about trying to read with Linux?
ACELab partner
PostPosted: May 29th, 2011, 2:00
i tried linux that the first thing i tried. :mrgreen:
i have nearly finished recovering my movies from the drive.
going to have to reload all dvd images back into each folder so going to take time arghhhhhhhhhhhhhhhhhhh
most of the tv shows i got on dvdrs
but dont want to search throu all and put them correctly in place
but dame seagate use to be good but they gone down hill
in a bigway
new drive and fails out of the box.
going toward samsung from now on
thanks all for your help
Users browsing this forum: Google [Bot] and 54 guests
