 Post subject: WD with a faint Squeel
PostPosted: May 26th, 2011, 9:04
500GB IDE WD5000AAKB
Very faint (electrical) noise coming off it, does not spin. checked the contacts on the board.
seized?
thanks
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: WD with a faint Squeel
PostPosted: May 26th, 2011, 9:06
Dropped ? 8)
PostPosted: May 26th, 2011, 9:07
details are vague, i think it probably has tho
PostPosted: May 26th, 2011, 9:12
I would test that board on a compatible broken/clicking (that you do not care for) drive that does not have motor issue. Does it spin? WD drives rarely have motor issues unless, like above mentioned, dropped or slammed with no shame.
PostPosted: May 26th, 2011, 9:17
good thinking, thanks
PostPosted: May 27th, 2011, 5:42
Your drive could be suffering from stiction or a seized spindle.
See this thread, but heed the warnings:
http://forums.seagate.com/t5/FreeAgent- ... 242#M11384
PostPosted: May 27th, 2011, 6:00
In a nutshell :
If the spindle is seized, bumping the drive in the (vane) attempt to make it spin can end with broken head and a good nice spickle/ring on the surface for sure that will kill new headset (= how to make recovery price skyrocket) or make things MUCH WORSE
If it is stiction, there are SAFE ways (for data) to fix it but this doesn't include slapping drives as it won't give you 2nd chances when thing go wrong, possibly endangering your wallet just in case data was from customer 8) .
Your data / your customer data , your choice.
Final note : WD is not Seagate and viceversa.
PostPosted: May 27th, 2011, 6:02
sound electrical like a short, not the usual buzzing or dropped/seized type noises. like very small aliens having a chat
PostPosted: May 27th, 2011, 6:11
Then make / have a real diagnose.
PostPosted: May 27th, 2011, 6:19
Head stuck under the ramp could be.
Angel Data Recovery
PostPosted: May 27th, 2011, 6:35
I agree with DR-Kiev's suggestion.
http://www.datasaversllc.com
PostPosted: May 27th, 2011, 8:04
You mean under ramp AND blocking pack ?
PostPosted: May 27th, 2011, 9:31
Yes
Angel Data Recovery
Users browsing this forum: No registered users and 102 guests
