 Post subject: Clicking noise already???
PostPosted: June 1st, 2011, 22:54
Hi. I have the following hard drive:
Seagate Barracuda st31000524As 1TB
Now, I only bought my system yesterday, and already noticed the hard drives clicking noise. The noise is persistent from when I turn it on to opening a web browser. It's not too loud, but noticeable. Is this normal? I'm a bit worried the guy who put my system together may have put an old hard drive, although it looks OK from the outside.
I should also note my system runs inside an Antec 300 tower. It has a grilled front end (for air flow), which may be why I'm hearing the noise (I'm used to the traditional closed towers)
Any insight would be appreciated.
Thanks in advance
 Post subject: Re: Clicking noise already???
PostPosted: June 1st, 2011, 23:44
I should also add that the computer is running fine. Also the fans are extremely quiet (maybe that's why the noise becomes obvious?)
PostPosted: June 2nd, 2011, 3:46
You should swap your drive with the supplier.
PostPosted: June 2nd, 2011, 4:07
Maybe normal, maybe not. You need some kind of backup.
I think I would add in a second drive and set it up as a raid 1 mirror.
Then if the noisy drive condition gets worse you shouldn't suffer total data loss.
The pc builder should be able to set this up for you.
PostPosted: June 2nd, 2011, 4:17
Maybe a bad PSU can be the origin of the problem.
ACELab partner
PostPosted: June 2nd, 2011, 6:01
@Michaelmoo,
Trying to diagnose a sound remotely, especially without giving a recording of it (but sometimes even with that), is prone to misinterpretation & incorrect analysis. :( It's like being asked to give an opinion about a song, without being sent an MP3 of it. :)
Are you saying that the noise stops completely, until you next power-on the system, once you've started the web browser?
Impossible to say from the limited description and no recording having been given. :(
One possibility is that this is the normal sound, especially if the AAM setting has been adjusted on the drive, to give fast (but noisy) seeks.
Try powering-on the system, and press whatever key is needed to enter BIOS setup (e.g. F2 or whatever) and just sit there for a few minutes. Is there any noise from the drive during that time or not? If not, and if the disk noises only start when you exit BIOS setup and boot the OS (after making no BIOS changes e.g. by pressing ESC), then it's probably just normal disk seek noises. If you hear repetitive clicks from the disk, even when just sitting in BIOS setup, then that is a concern.
You can check the Seagate manufacturing date from the top of the drive and it's s/n on the Seagate website warranty checker IIRC; or use a good SMART utility to read the raw power-on hours counter from the drive (this data can be altered, but is rarely done) - and that SMART data can also be checked for any other signs of concern
So those are a few things for you to consider doing, depending on how important (and how much of a concern) this is to you. :)
PostPosted: June 2nd, 2011, 8:32
Thanks guys for your help. So I've tried my best to do what I've asked you to do and here's what I came up with:
The noise does not seem to stop as long as my computer is on. And the frequency of "clicks" seems to increase with increasing computer activity (rulling out fans as the problem)
I did that. And no! There were no clicks when I entered the BIOS. It seems to begin only when the windows wants to start up.
Found that for you. The date code read: 11406. What does this mean?
I've also taken the time to open up my computer and actually record it for you guys. Yes, the noise is definitely from the hard disk. I've put the recorder right near it so you can try to hear. Basically, what I did during this interval is turn on my computer and then shut it down immediately. You can here the activity, especially when windows kicks in and starts loading. It wouldn't let me attach an mp4 file so I uploaded it to megaupload. Download link is:
http://www.megaupload.com/?d=6YRHC645
If you guys could give me a diagnosis I'd really appreciate it.
PostPosted: June 2nd, 2011, 10:46
You're welcome :) but then you turn-on the guilt later :(
Now that you've explained that the noises do not stop after you run the web browser (as you had originally implied they did), then this noise is related to disk I/O.
From this BIOS "power with no I/O" test result, you'll see my diagnosis in my previous posting.
Google seagate date code decoder and you'll see your answer - it's a new drive.
If, as your tone implies, you are trying to make me feel guilty for asking for a recording and all the effort that was for you to do it, then you're failing - you're just making me regret spending valuable time offering to help, by making a big deal out of a request for information to help with answering your question. If it's such a big deal to get the information, then don't do it and live with the result. Or if it isn't such a big deal, then why mention it.
Anyway, my current (non-PC) system can't play an MP4 file (there was a reason I mentioned MP3 :) ), so you'll have to wait for a response from someone who can play it. I think I've helped enough now and the results of my suggested BIOS test have answered your question with a high degree of confidence, as far as I'm concerned (the recorded sounds will help confirm my previously explained diagnosis, SMART raw data analysis may give extra confirmation, and checking the AAM setting may give an interesting result). Good luck.
PostPosted: June 2nd, 2011, 15:10
One further note: Depending on your amount of RAM, swap file size, and load on your system you could be accessing the HDD excessively. If you are using one of the "speedup" programs during internet access, they basically pre-load web pages onto your HDD for viewing so they load faster in your browser. This would result in increased drive access.
PostPosted: June 2nd, 2011, 15:34
Sounds ok to me. Typically if the heads are bad you're going to hear some sort of repetitive clicking, a pattern or something like that. To me that sounds like a computer just working and doing it's job. Anyone else care to confirm?
Dizi
PostPosted: June 2nd, 2011, 18:51
Thanks heaps guys. Oh and @ Vulcan, I'm not playing the guilt card, please don't take it that way! This means a lot to me (I paid a good amount for this system) that's why I went through the effort.
But that's the thing, it's a brand new hard disk. Maybe it's just that this particular brand of hard disk isn't top notch? I didn't notice this with my previous Samsung hard disk (but then again, it could be due to the quieter fans and grilled front end on my tower)
I've converted the file for you and anyone that couldn't open. Please take the time to check it out as I'd very much appreciate it. Again on Megaupload (sorry about the larger file size):
http://www.megaupload.com/?d=I0IZ32H6
Michael
PostPosted: June 4th, 2011, 20:59
Well I might see what the supplier can do for me.
It seems to be increasing (as I install more programs etc). If it was just the traditional disk search groan, I wouldn't mind. But the clicking might really cause problems.
Although, I've run a SMART analysis and a disk check and found no problems. It's really a problem if they can't do anything until the hard drive actually fails me (don't want to wait until then).
PostPosted: June 4th, 2011, 23:06
OK :)
I've downloaded & listened to the MP3 (thanks for that).
Apart from the obvious human-triggered sounds as the mic was moved/touched at the start & end, everything else I hear from the disks sounds normal; normal spin-up; normal seek sounds; normal spin-down. IMHO what you're calling "clicks" are actually the nomal "ticks" which occur during seeks - especially if the disk has been configured for higher seek performance (read about AAM on (S)ATA disks for info on this).
As I explained before, this also fits with your result of no "clicks" when displaying a BIOS screen - thus confirming that the "clicks" are heard only with normal I/O (which doesn't occur when displaying a BIOS screen).
FYI there are many subtleties to reviewing SMART data, which can be missed by the less-experienced, but that's a whole topic on its own.
Given that your only reported concern is the disk noise, my view is that there is nothing abnormal audible in that recording. You could investigate AAM settings (e.g. using HDDScan) if supported by this disk, if you want to see whether the noise can be reduced (at the potential expense of seek performance). It could also be that the mounting of the disk in that chassis is increasing the apparent disk noise level (e.g. resonance), or simply the holes in the case front, as you suggested, allowing you to hear more of the noise which was always present anyway.
In short, I think you're worrying unnecessarily about imminent disk failure based on the noises in that recording. :) Of course, always make sure that you have backups, as any disk can fail without warning.
PostPosted: June 8th, 2011, 2:09
Thanks everyone.
So I was paranoid and went and changed the hard disk. Turns out the sound is very similar to the one I suspected was faulty.
Normal disk checking can sound much like a Geiger counter apparently.
Thanks for your help guys.
PostPosted: June 8th, 2011, 13:52
Yes indeed, so now you can stop worrying. :) I suspect (as I said before - which is also what you mentioned at the beginning) that the new, different, case is making it easier to hear the normal disk noise, and so it is "different" for you, despite actually being normal. :)
Users browsing this forum: No registered users and 64 guests
