 Post subject: What is the BEST Proper way to record
PostPosted: June 8th, 2011, 7:16
Hi All,
am doing some sort of organizing my memory in hdd knocking clicks issue
i wanted to record the hdd sound and wanted the BEST/proper way to do that?
any idea?
sensitive MIC or any similar?
thank you
 Post subject: Re: What is the BEST Proper way to record
PostPosted: June 8th, 2011, 9:25
I use a recording stethoscope.
PostPosted: June 8th, 2011, 10:03
I've connected some cheap earphones to the mic plug on my sound card and stripped the one earphone housing and connected that up to a stethoscope, works well for a DIY job.
Data Recovery Cape Town
PostPosted: June 10th, 2011, 8:28
hehehe thnx both really,
am trying to get the best sound for those cases i solved to archive it and compare it for my own RnD
by having those sound will help alot others including me.
will try that :>
thnx
PostPosted: June 10th, 2011, 13:00
There are available those telephone microphones. They have a suction cup on them. I would think one could use that on the case of the drive and pick up the sound pretty good...
Users browsing this forum: Google [Bot] and 41 guests
