 Post subject: Seagare ST31000333AS - PCP
PostPosted: June 14th, 2011, 9:09
Hello members of the baord !
Problem:
- the BIOS does not show the HDD
- the pc needs a long time to boot
- windows does not show th disk
- the disk (if branchend) makes consistently a clack all 5-7 seconds
Therefore am looking for a PCP:
Seagate ST21000333AS
S/N: 6TE0755J
P/N: 9FZ136-568
FW: SD35
Date Code:09222
Site Code: SU
100512585 F M920K59W
The Seagate Custumer Service said, that this HD is excluded from the serie of
the defective HD. The HD contains very important informations and so I should like
try to recover the disk ..
Thanks for any good ideas,
J.Mohnen
 Post subject: Re: Seagare ST31000333AS - PCP
PostPosted: June 14th, 2011, 9:23
This does not sound like a PCB failure
PostPosted: June 14th, 2011, 10:18
I saw SD35 drives with busy bug but the Clicking u are describing is defiantly NOT a symptom of bad FW.
U can record the clacking an link it here for us to hear. But most likely it is not a DIY job.
PostPosted: June 14th, 2011, 11:54
Your best option would be to take your drive into a pro to make a proper diagnosis, so you can understand what's your drive problem.
PostPosted: June 14th, 2011, 21:02
You can obtain a terminal report from your drive.
See the following thread, but don't enter any of the commands:
http://forums.seagate.com/t5/Barracuda- ... 036#M19464
The following cable will probably be easier and safer to use than a Nokia CA-42 or any of its many variants:
Prolific USB to TTL Logic Cable (US$10):
http://www.serialstuff.com/products/Pro ... Cable.html
AIUI, the following test should help you determine whether the drive has a head fault. However, I'm not a data recovery professional, so others can advise you on this procedure.
How to Test Seagate Drives' Heads for HDD Repair:
http://www.datarecoverytools.co.uk/2011 ... dd-repair/
PostPosted: June 15th, 2011, 3:41
As stated on another post, you shouldn't run this last test if your data is important.
Users browsing this forum: No registered users and 268 guests
