 Post subject: 7200.12
PostPosted: June 13th, 2011, 15:59
Hi to all!! :mrgreen:
Terminal
Rst 0x20M
clicking drive
Is firmware CC35
ST31000528AS
BAD HEAD? or fw is corrupted? :shock:
Help..
Нет ничего невозможного
 Post subject: Re: 7200.12
PostPosted: June 13th, 2011, 16:46
I vote for heads. The only model I've seen with FW issues & Clicking is the 333AS
Data Recovery Ireland
PostPosted: June 14th, 2011, 11:54
Those ones normally it's heads.
PostPosted: June 14th, 2011, 21:03
How to Test Seagate Drives' Heads for HDD Repair:
http://www.datarecoverytools.co.uk/2011 ... dd-repair/
PostPosted: June 14th, 2011, 23:39
That's rather bad advice
1. This information related to ST10 Seagate drives. 7200.12 is not an ST10 drive
2. T4 test recalcs adaptives, so if you need data from a drive you shouldn't ever run this. This article clearly states REPAIR not data recovery but inexperienced user will not understand the difference until it's too late
This article will bring more harm than good
I suggest you never mention this link in your posts
PostPosted: June 15th, 2011, 3:49
Perfect idea for killing data on live drive ! :mrgreen:
PostPosted: June 15th, 2011, 4:50
I have posted the above URL on several occasions, so there have been plenty of opportunities to point out its potential for killing data on live drives, assuming that's correct. I even explicitly asked the data recovery community to confirm whether the procedure was safe, but noone did so ... until now.
BTW, thanks to Doomer for eventually setting me straight ... really.
PostPosted: June 15th, 2011, 5:31
When procedures are unchecked, unsafe or UNKNOWN would be better NOT to point in that direction.
Anyway someone will decide if it is necessary to cleanup this thread too for the sake of users that are redirected here by google or other way.
PostPosted: June 16th, 2011, 3:05
I am quite happy for this thread to remain exactly as it is. I don't have any problems with anything that I have written. My conscience is clear.
PostPosted: June 16th, 2011, 3:27
We too :mrgreen: .
Users browsing this forum: No registered users and 256 guests
