 Post subject: DeepSpar Disk Imager™ 3 versus PC3000
PostPosted: June 27th, 2011, 23:09
How well does the Disk Imager work if a motherboard BIOS does not see the drive? Is the primary benefit of PC3000 over the Disk Imager that it writes firmware? Will either of these work with SSD drives?
 Post subject: Re: DeepSpar Disk Imager™ 3 versus PC3000
PostPosted: June 28th, 2011, 18:23
DDI works when the HD is detected. PC3K works to repair the drive. They are completely diferent tools.
ACELab partner
PostPosted: June 29th, 2011, 11:07
Except one minor detail. DDI has the option to do hot swap using another drive, but then again in order for this to happen, you will need some other tool to address firmware issues to prepare for hot swap method.
Users browsing this forum: Google [Bot] and 63 guests
