 Post subject: Seagate ST2000DL001 busy
PostPosted: July 11th, 2011, 5:17
Hi i have a 2Tb Seagate LP ST2000DL001, it is recognised in Bios (model number, serial, capacity) but is always bsy.
can it be a head stuck?
any suggestions?
thanks in advance
 Post subject: Re: Seagate ST2000DL001 busy
PostPosted: July 11th, 2011, 5:32
Check PM.
Data Recovery Cape Town
PostPosted: July 11th, 2011, 5:43
Can be the BSY bug....
ACELab partner
PostPosted: July 11th, 2011, 6:04
as it is with the 7200.11?
PostPosted: July 11th, 2011, 6:26
athlesi7 wrote:
it is recognised in Bios (model number, serial, capacity).
If model/serial/capacity is normal then not BSY problem.
PostPosted: July 11th, 2011, 6:30
most probably smart problem
PostPosted: July 11th, 2011, 7:29
I've had 2 of these where clearing SMART brings the drive ready.
PostPosted: July 13th, 2011, 2:50
Thanks! Excellent job. Nick_CT is right, reset the SMART parameters and there you go.
should i trust the disk now? i should propably back up and send the drive to the warranty.
PostPosted: July 13th, 2011, 3:00
After SMART reset the drives, in my experience, worked for a few hours or few days, then went BSY again. The ones I worked on were RMA'd.
PostPosted: July 13th, 2011, 12:19
Don't trust it.
Get a replacement if possible through warranty.
PostPosted: July 14th, 2011, 9:54
You can scan it with MHDD.
data recovery Poland
PostPosted: September 20th, 2011, 12:31
Hi, I am having the exact same problem with the ST2000dl001. How did you clear SMART parameters? Is there a way to do it in a seagate terminal? Thanks
PostPosted: September 21st, 2011, 7:38
For the 7200.11 bsy bug fix it says the following:
F3 T>/1
F3 1>N1
this is a S.M.A.R.T. erase
tutorial-resolve-lba-seagate-7200-bios-don-recognize-t11040.html
But I would test it on another drive first just to confirm it works ok.
Remember you do this at your own risk
Loki
PostPosted: October 24th, 2011, 6:29
Thanks Loki. Tried resetting SMART and comes to life for a few minutes and then spins down so cannot access. Any suggestions?
PostPosted: October 24th, 2011, 10:59
OK, so before you clear SMART, disk span up, no sounds whatsoever, kept spinning and stayed BSY?
Then, you cleared SMART and disk spins up, detects (you said "it comes to life") and spins down? Or it only spins up and down?
PostPosted: March 25th, 2017, 10:43
Wow i know this is old but i have the same problem, BSY and not terminal trying to short PCB but no luck, can someone shed some light please.
Thanks.
Data Recovery in the Dominican Republic
https://www.recuperamidata.com/
Users browsing this forum: No registered users and 143 guests
