 Post subject: 7200.11 SA problem
PostPosted: July 20th, 2011, 12:16
hello
ST31000333AS
We have not drive that is common not detected in BIOS
We have done N1, etc.
When we start m0,2,2,.... the drive goes immediatelly off.
Know somebody ?
HEADs are OK.
 Post subject: Re: 7200.11 SA problem
PostPosted: July 20th, 2011, 12:25
What's the terminal log??
ACELab partner
PostPosted: July 20th, 2011, 12:40
no errors in terminal
when is started m0, the drive goes off
PostPosted: July 20th, 2011, 12:49
My guess...the drive was misdiagnosed.
How do you know it isn't a head issue? What firmware version is the drive? Show us the terminal log when you power the drive on.
PostPosted: July 20th, 2011, 13:16
When you say "goes off", you mean "spins down"?
PostPosted: July 20th, 2011, 13:30
yes spins down
PostPosted: July 20th, 2011, 14:26
You still didn't posted the terminal log, when you power up the drive.
ACELab partner
PostPosted: July 20th, 2011, 18:17
What do you use to get terminal log?
PostPosted: July 21st, 2011, 7:45
I see similar problem before with firmware LC15. After attempts to manually repair with 'm' command spindle stops. Be patient, spindle will start again and repair should complete.
This is assuming that, as lcoughey says, diagnosis is correct...
Users browsing this forum: Google [Bot] and 57 guests
