 Post subject: WD5000AADS not detected by bios
PostPosted: July 22nd, 2011, 18:19
Drive died after pc was down in standby. Now the drive is not detected by bios anymore. Drive spins up with no unusual clicking or knocking ounds.
Model: WD5000AADS - 00S9B0
500 GB SATA drive
Anybody can help with a solution to fix this?
 Post subject: Re: WD5000AADS not detected by bios
PostPosted: July 26th, 2011, 11:55
dragfly drive i think. See them on occasion with corrupt translator. Indepth diagnostics needed. Sry cant say much with info given...
PostPosted: July 27th, 2011, 17:24
Here is some pictures of the drive and board.
I got a spare disk, will replacing the board maybe help?
PostPosted: July 27th, 2011, 18:55
Online
No.
PostPosted: July 28th, 2011, 10:46
Ill correct unknown by saying "unlikly" There is a chance ur donor PCB will have same adaptive info close enough and there is a chance PCB is the problem with ur drive. But the chance is slim.
Record the sound ur drive makes. The recording should strt BEFORE u apply the power to the drive since i want to hear the calibration sound it makes.
PostPosted: July 28th, 2011, 11:30
500 GB SATA drive
Does it stay spinning up? Or spin down?
If it stays spinning there's a reasonable chance it's a firmware issue.
Very very unlikely a new PCB will do anything.
PostPosted: July 28th, 2011, 18:27
Drive continues to spin after poweron.
But it does not have the same sounds as the working drive. About 10 sec. after poweron there is 9 barely hearable ticks with 1 second interval.
btw, tried a pcb swap with no succes.
PostPosted: July 29th, 2011, 7:20
Online
FW corruption and/or head(s) problem. As Alexii said, try to record the sound.
Good luck
PostPosted: July 29th, 2011, 15:36
Here is the sound recording of the disk.
http://www.youtube.com/watch?v=TUYA2qrUnpg
PostPosted: July 29th, 2011, 16:41
Online
Most likely FW issue, unfortunately, there's nothing you can do but sending it to a pro.
If you want to do it yourself you will need complex tools software/hardware and knowledge to use them.
If you have one of those tools ( Atola / PC3k UDMA / SD tools .. etc ) we can help you to solve this issue, otherwise there's nothing you can do.
PostPosted: July 30th, 2011, 11:58
No DIY solution, pro help required
PostPosted: August 1st, 2011, 16:34
I don't have any of thoose pro tools. Is it maybe possible to do anything to fix the firmware through a TTL interface?
PostPosted: August 1st, 2011, 17:13
Online
No, we are talking about WESTERN DIGITAL. And not "unlikely" this time Alexii. :)
PostPosted: August 3rd, 2011, 14:34
i hear the calibration and looks like the drive will come ready but unable to acess user area. Maybe my shot in the dark about dead translator was right =) In any case unknown is correct. No unlikely this time. Pro help needed.
Users browsing this forum: Google [Bot], pepe and 126 guests
