 Post subject: hELP THIS TOPIC HARD DISK IS NOT SHOW IN BIOS
PostPosted: May 13th, 2014, 2:00
2>Reset
1024k x 16 DRAM
NHAWK - 1_Disk S-LE 11-14-07_16:30
HM SFI
(P)SATA Reset
Bad AppCodeKey
Unable To Load Overlay 00|0013
T>((VALID Cert Disk Code Detected - Revision # .0BK
Current FS Buffer usage: 12800 bytes
FS_INODE_TABLE_BUFFER: 3e5
FS_DIR_ENTRY_BUFFER: 3e7
FS_SCRATCH_BUFFER: 3e9
FS_INDIR_BLOCKS_BUFFER: 3eb
FS_BUFFER: 3fb
T>i4,1,22
T>Reset
1024k x 16 DRAM
Buzz HM SFI
(P)SATA Reset
Bad AppCodeKey
T>/1
1>N1
Bad AppCodeKey
Unable To Load Overlay 00|0004
1>(
1>/t
T>i4,1,22
Command Inactive - No VALID Cert Code Detected
FS_BUFFER: 3fb
T>i4,1,22
T>/1
1>N1
Can't execute AT overlay calls when cert code is present
smartres.c - ovl L1 failed
1>((VALID Cert Disk Code Detected - Revision # .0BK
FS_BUFFER: 3fb
1>i4,1,22
1>/t
FS_BUFFER: 3fb
T>i4,1,22
T>øReset
1024k x 16 DRAM
HM SFI
(P)SATA Reset
Bad AppCodeKey
T>(
T>/1
1>N1
Bad AppCodeKey
1>N1
Bad AppCodeKey
1>/t
T>i4,1,22
FS_BUFFER: 3fb
T>i4,1,22
T>F11
T>f
T>F,,11
stuffres.c - serial port set stuff failed
FS_BUFFER: 3fb
T>i4,1,22
T>F,,11
T>NHAWK2HD - 1_Disk 4.AAB 12-04-07 17:00 AAE,NH_1D_2H_S,14
Built for NHAWK2HD,PITKIN,Redback,TI1843 PreAmp,Agere7539 PreAmp,McKinleyLite,1Disk,220 Servos,7200RPM,8Pole,133MHz,RwFeat=0002,VBAR
Eng Rev = .0DT
Compat/Hardware = .6D1
CERT Rev = .0BK
.0BK
Mask Rom Rev = S-LE
Orig Code = AAZ140 NHAWK_NH_140.0DT.0BK
T>i4,1,22
T>/1
1>N1
1>(
1>/
T>/1
1>N1
FS_BUFFER: 3fb
1>(
1>/
T>/1
1>N1
1>(
1>/t
T>n2
T>N2,AA,22
T>(
FS_BUFFER: 3fb
T>I4,1,22
Begin Test 02
Users browsing this forum: Google [Bot] and 94 guests
