 Post subject: Seagate BlackArmor 400
PostPosted: July 26th, 2011, 11:04
I have 4 disks each 2 TB, configured as Raid five, I need to recover the data from the NAS array, i attached the drives as seen by R-studio, this may help
I need the offset parity and stripe size
thank you
I 've been told that Dr. Keiv will solve it, he is a professor in DR.
 Post subject: Re: Seagate BlackArmor 400
PostPosted: July 26th, 2011, 11:33
Have you tried http://runtime.org/nas-recovery.htm
It might be worth a try?
Loki
PostPosted: July 26th, 2011, 11:54
yes dr.kiev is the one for RAID
PostPosted: July 27th, 2011, 10:51
You are sure is configured as RAID5?
R-Studio can help, but does not handle EXT well. Use different software
You should ask client original problem and if any disks were offline during or before the main failure.
You try to rebuild already? What did you try?
Did you try NAS software from runtime software?
Do you have experience building RAID5 before?
Users browsing this forum: Google [Bot] and 103 guests
