 Post subject: Format Corrupted Partition Table
PostPosted: August 1st, 2011, 15:15
I have a Hitachi 3tb drive. Power supply was shorted out and corrupted drive. I had 2.2tb of data on drive, thus 800gb free. I recovered my data(through data rescue 3), then when I went to reformat the drive it will only format the 800gb that was free.
My question is, how do I format the entire drive? I have tried PTDD for windows, I have boxes that run LINUX, OSX, and 7. So if anyone knows of a base layer format tool that can get past a corrupted partition table please let me know.
I am also confused how I could recover the data, but not be able to format it.
 Post subject: Re: Format Corrupted Partition Table
PostPosted: August 1st, 2011, 17:11
You could try runnning cmd as admin in win7 & then run diskpart. Select the correct disk & then run the clean command or run the clean all command to zero wipe the entire drive but it will take ages for a 3tb drive. Then try formatting it again.
Basic commands are
List disk
Select disk
List partition
Select partition
Clean
Clean all
Create partition primary
Active
Assign
Loki
Users browsing this forum: Google [Bot] and 148 guests
