 Post subject: Western Digital My Passport Pass Problem..
PostPosted: August 5th, 2011, 0:29
I have a "Western Digital My Passport SE" whose data are password protected.
I signed. The unit is accidentally unplugged, so when it is reconnected, I was prompted for a password. I entered, but all I get is the window that says "the password is incorrect"... I entered the correct password (I'm sure, for several reasons (use the same, before detaching it worked...)) Now I no longer have access to data ... Is there a solution to access data without losing them?
You can check this links for more informatin;
http://community.wdc.com/t5/My-Passport ... td-p/23756
http://community.wdc.com/t5/My-Passport ... d-p/223788
http://community.wdc.com/t5/My-Passport ... d-p/223534
Thanks..
 Post subject: Re: Western Digital My Passport Pass Problem..
PostPosted: August 6th, 2011, 15:47
for WD passport password retries limitation which i guess 5 times
then ur drive will be locked (BAD) and will ask to format
in such case, if you exceed the 5 times retries (wrong password)
ur reaching a DEAD END am afraid
PostPosted: August 6th, 2011, 23:18
Especially if don't want to spend.
Users browsing this forum: Google [Bot] and 154 guests
