 Post subject: Quantum Fireball CR 8.4 PCB
PostPosted: August 9th, 2011, 7:50
I have a Quantum Fireball CR series 8.4GB with a burned PCB
PCB: CR84A013 Rev 01-B
Will a simple swap of the PCB work?
Do I need to find exact match?
I have found on ebay P/N
CR84A011 CR84A2F1
Will any of those two will work?
Thanks for your help.
 Post subject: Re: Quantum Fireball CR 8.4 PCB
PostPosted: August 9th, 2011, 8:33
Don't see QF for ages...
Well, there you should get a LCT 10/15/20 etc. anything, update this one...
If the burn is limited to PCB only then definitely will work with the simple PCB swap for your case.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
Users browsing this forum: No registered users and 200 guests
