 Post subject: Western Digital: WD2500BEVT-22ZT0 -failed, many pics + audio
PostPosted: August 12th, 2011, 3:16
Hello guys, so recently my drive stooped to work, at first it would still show up on pc but do not recognize it, now it doesn't. Pls guys take a look and tell me if its likely to be pcb issue.
Main controller: 8816745N-tfj1 ypml620ah 0839 b1p
Motor combo: Smooth L7206 1.2
2060-701499-000 rev A
XT 5H19 CBHQ 7 0004200 9 204
Model: WD2500BEVT-22ZCT0
DCM: HBCTJBNB
You can find pictures here:
http://www.mediafire.com/?11hansspgq5ux#0,2
And video with audio is here:
http://www.mediafire.com/?yg3udiwscl0i2cb
 Post subject: Re: Western Digital: WD2500BEVT-22ZT0 -failed, many pics + a
PostPosted: August 12th, 2011, 8:38
Not likely.
http://www.datasaversllc.com
PostPosted: August 12th, 2011, 8:55
It's "NO" for me too.
PostPosted: August 12th, 2011, 8:57
99.9% not PCB
PostPosted: August 12th, 2011, 11:04
FW / heads. Even if it was a PCB there's no DIY, sorry.
PostPosted: August 12th, 2011, 22:44
wow, thats pretty dissatisfactory :(, i was hoping it was pcb. So next question comes up what to do next?
PostPosted: August 12th, 2011, 23:14
Simple send To jono-ats posted above he is in Atlanta Ga his prices are very reasonable great service. That is if you truly want a chance at recovering your data.
PostPosted: August 12th, 2011, 23:38
i might consider that for one of my other drives, but this one is not as valuable, to fix would it be possible by swapping heads from another donor drive?
PostPosted: August 12th, 2011, 23:46
You run into the WD head alignment issue the moment you remove the top cover. Do you have experience with head swaps tools etc ?
PostPosted: August 13th, 2011, 0:05
I'm Russian.
Thanks for all help, will tell you how it went ;)
PostPosted: August 15th, 2011, 12:46
Check it in MHDD. Maybe it'll be BUSY for a while and then you can check its condition (SMART).
data recovery Poland
Users browsing this forum: Google [Bot] and 213 guests
